solid to hydraulic cam? #803129
09/16/10 03:53 PM
09/16/10 03:53 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
When changing from a solid lifter cam to a hydraulic would you change the springs?Will the push rod length stay the same?
My son bought a '77 warlock 4x4 and we're planning on swapping out the 360 in the '70 dart to the truck.
The 360 has kb 107's,j-heads 202/160 with the factory adjustable rockers,LD 340 and the hughes solid cam.
I can't find the cam card but I think it was HE3844 and the duration was 238/244 @ .050 which I assume would be too wild for a truck.The springs also came from hughes and were matched to this cam.
Anybody know of a good cam with good power and torque for a 4x4 truck?
Re: solid to hydraulic cam? [Re: 70SWGR] #803130
09/16/10 04:26 PM
09/16/10 04:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Personally I would put it in and try it. The springs IMO will work for you. The push rods for a hydraulic cam are way shorter due to the lifter cup location. Are keeping the adjustable rockers???
Re: solid to hydraulic cam? [Re: MoparforLife] #803131
09/16/10 07:39 PM
09/16/10 07:39 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Did you think about talking to Hughes?
Re: solid to hydraulic cam? [Re: babarracuda] #803132
09/16/10 10:55 PM
09/16/10 10:55 PM
Colorado
jr70swgr Offline
jr70swgr  Offline
Colorado
Im his son...
If we try that cam will it cause any problems with the power brakes due to the vacum????
Re: solid to hydraulic cam? [Re: jr70swgr] #803133
09/16/10 11:23 PM
09/16/10 11:23 PM
IN
ahy Offline
ahy  Offline
IN
Power brakes seem to do OK around 12" Hg vacuum and are really happy at 18+. From a previous post I remember idle vacuum was around 10-11" with the big cam. If that's right vacuum is the low side of marginal for PB... may work OK may not. One step smaller on the cam could make a difference on the PB
I also remember compression was reported at around 10.5. With a smaller cam, detonation may be a problem with a much smaller cam and pump gas.
I'd suggest trying the big cam engine as is or rebuilding the old one to truck specs... less compression and cam.
Re: solid to hydraulic cam? [Re: babarracuda] #803134
09/17/10 01:39 AM
09/17/10 01:39 AM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
Already done that just wanted to hear opinions from members here.
Re: solid to hydraulic cam? [Re: ahy] #803135
09/17/10 11:50 AM
09/17/10 11:50 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'd tend to lean this way as well.
OP, what is your altitude? 10.5 compression at sea level isn't a problem at altitude, but your vacuum also suffers. You might want to do a cranking comp. test to see what you have.
Is the truck staying at altitude? I need more info...
Brian, I got your PM. There is a Mopar shop in Denver, but I'm not comfy recommending them. Most of the guys that need work farmed out use a guy that works out of his house/shop.
Re: solid to hydraulic cam? [Re: 64Post] #803136
09/17/10 10:34 PM
09/17/10 10:34 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
My son lives east of Aurora but will be driving in the mountains plus use the truck for towing atv's,his friend has a cabin near grand lake.
Could you give me the phone number of the guy working out of his home/shop?
Do you know anything about the shop in Eaton,CO?
Thanks,
Brian
Re: solid to hydraulic cam? [Re: 70SWGR] #803137
09/18/10 12:22 AM
09/18/10 12:22 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Thanks,
Brian
Let me make a call or two. Louie can be tough to schedule at times. He's in Ken Caryl near Bandimere.
I think the guy in Eaton is John Wolfe. Feedback is about 50/50 from what I hear.
