I cannot find these parts! Any ideas?? #802737
09/16/10 09:38 AM
09/16/10 09:38 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I can't seem to find these parts for an 8 3/4. Are these reproduced or will I have to search high and low??
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: I cannot find these parts! Any ideas?? [Re: knyech1] #802738
09/16/10 09:40 AM
09/16/10 09:40 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Have you tried a local salvage yard?
68 Charger
70 Cuda
Re: I cannot find these parts! Any ideas?? [Re: knyech1] #802739
09/16/10 11:21 AM
09/16/10 11:21 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
From what I know none are repoed.Probally bone yard stuff.The wheel cyl pins I believe are still avaliable.With all the guys goind rear disc someone should have some.The park stuff is size specific.If you have 11 inch brakes you need 11 inch hardware.The why cyl pins Im not 100% sure on.Rocky
Chrysler Firepower
Re: I cannot find these parts! Any ideas?? [Re: therocks] #802740
09/16/10 11:27 AM
09/16/10 11:27 AM
scratchnfotraction Offline
PM sent
Re: I cannot find these parts! Any ideas?? [Re: therocks] #802741
09/16/10 11:29 AM
09/16/10 11:29 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
The wheel cylinder pushrods are available at YearOne, at around $17 each. As suggested, I'd probably look around salvage yards. Good luck.
Roger
Re: I cannot find these parts! Any ideas?? [Re: Fab64] #802742
09/16/10 12:10 PM
09/16/10 12:10 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
Have you tried Rock Auto...thay usualy have some brake hardware.
Re: I cannot find these parts! Any ideas?? [Re: Fab64] #802743
09/16/10 12:14 PM
09/16/10 12:14 PM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Advance Auto shows the push rods at 3.49, and
also show adjuster hardware.
Re: I cannot find these parts! Any ideas?? [Re: knyech1] #802744
09/16/10 12:52 PM
09/16/10 12:52 PM
Locomotion Offline
Locomotion  Offline
If they are the 2"x10" brake assemblies from a B or E body with big bolt pattern, I believe the whole assemblies will swap over from later '70's and 80's RWD Mopars, like Aspens, Diplomates, etc. Some individual parts may also interchange regardless of the rear end it comes off of..
Re: I cannot find these parts! Any ideas?? [Re: Locomotion] #802745
09/17/10 10:35 AM
09/17/10 10:35 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Wow lots of answers. Thanks guys. I haven't tried the local yard since I bought this rear. Thought I had all the parts but I obviously did not. Thank you for all the help guys I will continue to try this for my questions when I have them!!
Re: I cannot find these parts! Any ideas?? [Re: knyech1] #802746
09/17/10 04:24 PM
09/17/10 04:24 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
try napa-they have a lot of old stuff.
Re: I cannot find these parts! Any ideas?? [Re: ohiodemon] #802747
09/18/10 12:57 PM
09/18/10 12:57 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
usually those 8 3/4 backing plates interchange with the 8 1/4's and the parts on there plate are typically the same too.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: I cannot find these parts! Any ideas?? [Re: ohiodemon] #802748
09/18/10 01:13 PM
09/18/10 01:13 PM
Under My Car
Mopar_Country Offline
Under My Car
It's where I got a lot of my parts for my 8 3/4.
