Re: 340 cam suggestions needed [Re: 451Mopar] #802545
09/23/10 12:59 PM
09/23/10 12:59 PM
Menomonie,wi
menomoniemopars Offline OP
Menomonie,wi
Yea That is what I told the builder was to keep it at 10.1 nothing more. So 106 will be good? if we went to 104 could be too much closing the valve earlier yet?.. What I meant is if i go to 102 from the other comment, doesn't the idle get choppier being a earlier ICL or no?.. I plan on doing the dist mod also.. thinking this cam will like about 15-18 initial? Being a street car it shouldn't be a dog even with the his current gear, and the 11" 2400 conv right?He wants to be able to have a nice power band and not be a pig til it comes up on the cam when he tries to goose it.. thanks guys! Really appreciate it!
Re: 340 cam suggestions needed [Re: menomoniemopars] #802546
09/23/10 03:40 PM
09/23/10 03:40 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Keep at it Darby, It will run well. The distributor mod is a must, 15-18 initial 34/35 total should be in the ball park. With the availabe replacement pistons, I think your compression will be closer to 9-91/2:1
allthough I have Aluminum heads, I used a thinner head gasket to get compression at 10:1 the block was also deck quite a bit. I have often used the 87 octane to top off the tank after racing and street drive my junk with no ping. The only time I got pinging was before limiting advance.
Good luck, see you this weekend??
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 340 cam suggestions needed [Re: 73swinger] #802547
09/23/10 06:24 PM
09/23/10 06:24 PM
Menomonie,wi
Menomonie,wi
How did u know it was me Chris? lol.
Yes I plan on being there sunday.. did some rear suspension mods.. hoping for some traction and 11.60's!..
Re: 340 cam suggestions needed [Re: menomoniemopars] #802548
10/14/10 03:15 PM
10/14/10 03:15 PM
Menomonie,wi
Menomonie,wi
Well according to the dyno today it made 376 hp @ 6000! and 377 torque at 4500....
Re: 340 cam suggestions needed [Re: menomoniemopars] #802549
10/14/10 06:27 PM
10/14/10 06:27 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Nice numbers for a mild build.
Re: 340 cam suggestions needed [Re: menomoniemopars] #802550
10/14/10 06:31 PM
10/14/10 06:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Nice numbers.
That 280/474 cam is not a really small stick from a Dur at .050. It's in the 238 range IIRC.
Re: 340 cam suggestions needed [Re: RobX4406] #802551
10/14/10 09:33 PM
10/14/10 09:33 PM
Menomonie,wi
Menomonie,wi
Nice numbers.
thanks yes u are correct it is 238 @.050.. it will need the dizzy worked on tho as it was idling at 1100 my brother said , but making 12" of vac! once i give it more int it will be even snappier, that was at 34 total and his crappy old headers it will be using the TTI stepped headers he bought for it also..
Chris
He is happy thats for sure! see ya saturday man! I got new tires in back and new QA1's Up front now! Hope to get warned for having no roll bar!
Re: 340 cam suggestions needed [Re: menomoniemopars] #802552
10/15/10 02:18 PM
10/15/10 02:18 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Souds like it's gonna run good for you. It's gonna want more than 2400 stall tho.
Re: 340 cam suggestions needed [Re: forphorty] #802553
10/15/10 03:19 PM
10/15/10 03:19 PM
Menomonie,wi
Menomonie,wi
Well according to my brother it was making 350 ftlbs at 3000, so i think it may be ok.. This is just a nice cruiser , doubt it will see the track by him
