Re: Running on E-85
[Re: DusTed74]
#802199
09/16/10 12:10 AM
09/16/10 12:10 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Well 8.1:1 comperssion will not work!!! More like 11.2:1 or more with some Elde Alumumn heads. Carb must be sized for more fuel flow. There are more mods that must be done too. But not a bad deal to work out.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: Running on E-85
[Re: Dave_J]
#802200
09/16/10 02:03 AM
09/16/10 02:03 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
what compression do the new flex cars have that run on e85.....???
certainly not 12 to...probably 9 to 1...
search google for E-85...a ton of info out there.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Running on E-85
[Re: 70AARcuda]
#802201
09/16/10 05:32 AM
09/16/10 05:32 AM
Dave_J
Auburn WA
Flex Fuel cars/trucks must run on pump gas too so they have lower compression. When you run them on E85 thier a total dog.
Re: Running on E-85
[Re: DennisH ]
#802204
09/16/10 09:18 AM
09/16/10 09:18 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A low compression engine will run just fine on it, even better than gas, however... it will suck fuel like crazy. If you don't want to build an even bigger gas hog than a 440 already is you need to bump the compression way up as in 12 to one. Flex fuel cars still have low compression gasoline engines not e-85 engines. I have never heard anyone (that actually owned one) claim they go slower, as a matter of fact they go faster and the gas gauge goes down faster also. If the engine was desighned from scratch to run on e-85 then the mpg differance would be little if any. I ran it in my 5.9 durango 99 neon 68 cuda with the MPG motor 95 maxima on a regular basis, none were flex fuel engines and MPG hardly changed at all and in some cases (maxima)mpg improved, the flex fuel computer dumps in more fuel. The only time I had a problem with e-85 was the neon but after the first 1/2 tank it was fine, I think it removed water in the bottom of the tank.
Re: Running on E-85
[Re: DusTed74]
#802207
09/16/10 09:10 PM
09/16/10 09:10 PM
HotRodDave
Kalispell Mt.
E-85 brings extra oxygen with it chemically. Since the big limiting factor in most engines ability to make HP is the air and more importantly oxygen they can take in, E-85 can make more HP if you increase the fuel flow at the same time you switch to e-85, it is like pouring in liquid oxygen witch has a lot more oxygen molecules than oxygen in a gas state like air.
Also since the whisky in it evaporates very quickly it cools the air and lets the engine breath in even more oxygen and it allows more compression on top of the already high octane rateing.
Contrary to popular beleif you do not HAVE to add more fuel for the engine to run, yes it will lean it out but it still does not burn as hot as a lean engine on gasoline and in my experiance never hurt anything.
Re: Running on E-85
[Re: HotRodDave]
#802208
09/16/10 10:04 PM
09/16/10 10:04 PM
RapidRobert
I'm considering building a max MPG 318. Would it be worth it to do the E85 mods (high CR/carb mods etc) from scratch?
Re: Running on E-85
[Re: RapidRobert]
#802209
09/16/10 11:17 PM
09/16/10 11:17 PM
HotRodDave
Kalispell Mt.
I would have loved to try about 11 or 12 to one compression on mine. I don't think it would get much better MPG than a gas motor but it would have more power for sure.
Re: Running on E-85
[Re: Crizila]
#802211
09/17/10 07:25 AM
09/17/10 07:25 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Basicly if you have or build a high compression race motor you can run it on race gas or with a modified carb,run it on E-85. If you can buy E-85 locally use it, it's generally cheaper than pump gas. Other than the carb change you can go either way,(that's assuming your fuel system is up to the extra volume, most race cars fuel systems are overkill to begin with). The motor will run 10-20 degrees cooler,and make a little more hp. What's not to like? ![](/ubbthreads/images/graemlins/shruggy.gif) . On the street I generally got within 10% of my best gasoline mileage IF I drove nice. E-85 LOVES compression, I'll say it again E-85 LOVES COMPRESSION. You'll have a hard time making as good a mileage with E-85 but you can come real close. If I build another E-85 motor it will be at 13.5-14-1. Dave
Re: Running on E-85
[Re: crlush]
#802213
09/17/10 02:10 PM
09/17/10 02:10 PM
HotRodDave
Kalispell Mt.
you can drink ethanol so it is not gonna hurt your fuel lines. Methanol on the other hand, bad stuff, very corrosive.
Re: Running on E-85
[Re: roadrunninMark]
#802215
09/18/10 12:29 AM
09/18/10 12:29 AM
Posts: 7,506 Az
Crizila
Az
I wouldn't. Teflon or stainless would be my choices.
Fastest 300
Re: Running on E-85
[Re: wireweld]
#802217
09/18/10 11:32 AM
09/18/10 11:32 AM
HotRodDave
Kalispell Mt.
E-85 alone makes a few more HP no matter the compression. 3 points of compression make a big differance in power, especially TQ. Now imagine doing both at the same time. By makeing those changes alone you should get a very nice boost in power, I would expect around %10 more power give or take a little from there. Also the smell of combusted e-85 is much easier on the nostrils and eye balls than gasoline.
I think it would be worth it, even if it meant pulling the motor down and swapping pistons. I sure wish we had e-85 here. I would bump the compression a little in my cuda and put in a smaller cam, the one I am putting in is a little bigger than I like so it can bleed off a little cylinder preasure.
