727 input shaft seal leaking on a fresh rebuild. #801062
09/14/10 09:51 AM
09/14/10 09:51 AM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
A couple of months ago I rebuilt my very first 727. You can imagine my surprise when it worked perfectly during a couple of road tests.
I just knew something was going to go wrong, and now my fears have been realized. After driving the truck and parking it, I'll get 5-10 drops of ATF dripping from inside the bellhousing and running down to the underside of it.
What are the odds that a brand new input seal are bad? I remember checking the torque converter hub for burrs and it was smooth, so I'm not sure if that is the issue.
I really wish I knew where I went wrong on that one, because if I'm going to pull it down to replace, It's not the most fun thing in the world to do (NP205 transfer case hanging off the back of it is heavy for just little ol' me).
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Pat_Whalen] #801063
09/14/10 10:02 AM
09/14/10 10:02 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Did you put a coating of grease on the seal where the converter rides. It is not all that common but you know s*** happens. Big thing is it works right.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: MoparforLife] #801064
09/14/10 10:39 AM
09/14/10 10:39 AM
scratchnfotraction Offline
vent hole is there above the input shaft also,just check and make sure its not over filled
when my 727 was over filled and ran real hard it would spit it out the vent
was it a good seal,I have gotten were I wount use the cheap seals,I go to the dealer and get a mopar seal for that spot for sure
drop the xfer off the back of it first would be they way to go
your right,no fun at all on a 4x4,at least you dont have to jack it up as high
with greese or dip in atf,just so its not dry on start up
good luck pat
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: scratchnfotraction] #801065
09/14/10 11:36 AM
09/14/10 11:36 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agreed on making sure trans is not overfilled.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: buildanother] #801066
09/14/10 11:43 AM
09/14/10 11:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Agreed on making sure trans is not overfilled. [/quote
the fluid expands quite a bit hot!
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Dodgem] #801067
09/14/10 11:59 AM
09/14/10 11:59 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Did you have the converter hanging on the input shaft since the tranny was rebuilt? I've heard the weight of it can distort the shape of the seal, then when it's installed the seal will leak.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: 6pkaar] #801068
09/14/10 12:52 PM
09/14/10 12:52 PM
florida
74fldart Offline
74fldart  Offline
florida
i feel your pain, i rebuilt my 1st 727 2 yrs back and had a main seal leak from day one and i havent even driven the car yet (still a running project) but it got so bad a few weeks ago that i decided to pull the tran and replace the seal. i did skimp and use some cheap parts when i reb uilt it, so i went to carquest and got a good seal and now it doesnt leak one drop.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Pat_Whalen] #801069
09/14/10 04:51 PM
09/14/10 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you saying that the fluid only drips from the bell when sitting shut off or is this just the only time you've looked?
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Pat_Whalen] #801070
09/14/10 04:56 PM
09/14/10 04:56 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Take the dust-cover off and point the vehicle down-hill slightly and see if there is a leak then.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Pat_Whalen] #801071
09/14/10 05:04 PM
09/14/10 05:04 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Did you change the bushing that supports the converter snout?
Edit: I think they call that the pump drive bushing? Is there a new one?
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Dean_Kuzluzski] #801072
09/14/10 05:14 PM
09/14/10 05:14 PM
Amherst,NY
challengermike Offline
Amherst,NY
did you fill it in neutral,they dont pump in park.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Pat_Whalen] #801073
09/14/10 05:30 PM
09/14/10 05:30 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I chased an elusive leak like forever until I found that tranny fluid was "wicking" at the front of the pan so that it looked like it was coming from the converter area. Very deceptive.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Commando1] #801074
09/14/10 08:19 PM
09/14/10 08:19 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Thanks for all the responses, guys. I'll try and answer all the questions at once.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: MoparforLife] #801075
09/14/10 08:20 PM
09/14/10 08:20 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
No kidding. I was very surprised/happy when it actually shifted properly and doesn't appear to have any other major defects.
If memory serves me correctly, I did cover the seal in ATF, not grease. Should it have been grease? If so, what kind?
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: scratchnfotraction] #801076
09/14/10 08:21 PM
09/14/10 08:21 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
good luck pat
Mike,
I relocated my vent hole to the top of the case and plugged the old vent hole location. I wish it were that easy.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: 6pkaar] #801077
09/14/10 08:22 PM
09/14/10 08:22 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Negative, converter only went on when the trans was ready to be installed. I heard about this and made a point not to do that.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: John_Kunkel] #801078
09/14/10 08:24 PM
09/14/10 08:24 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
If I wipe the bell clean and let it sit, no dripping.
If I start it and run it in the driveway in park, a small "stream" will form on the underside of the bell but not drip (this may be fluid left over from inside of the bell since I typically park uphill.
If I park it in the driveway after driving it and getting it up to temperature, that is when five-10 drips will appear on the ground directly under the bell, and then a small "almost drop" will form, hanging there, taunting me. Until I wipe it away and repeat the cycle.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: dOoC] #801079
09/14/10 08:25 PM
09/14/10 08:25 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
No dust cover installed yet.
I'll try parking it downhill today after I take it for a ride.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: Dean_Kuzluzski] #801080
09/14/10 08:26 PM
09/14/10 08:26 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Yes, the pump drive bushing was changed.
Re: 727 input shaft seal leaking on a fresh rebuild. [Re: challengermike] #801081
09/14/10 08:28 PM
09/14/10 08:28 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
I don't want to say one way or the other. I don't recall filling it in neutral, but I do remember checking it properly after driving it around, letting it sit, put in neutral on level ground and it was full.
