Re: Aftermarket tach hookup
[Re: stumpy]
#800230
09/13/10 04:09 PM
09/13/10 04:09 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
How about ground?
My mistake! I just went out and popped the cap and it looks like some electronic ignition as been added, Pertronics maybe? I assumed it was points because it was not the big HEI type distributor. So, how would I hook this up?
[Re: RodStRace]
#800232
09/13/10 04:47 PM
09/13/10 04:47 PM
SeventyGTX
Fallon, Nv
Should connect the same. Pull the tach and see if there is a switch in the circuit board. 4-6-8.
I took it apart and there is no provision for the amount of cylinders. ![](/ubbthreads/images/graemlins/shruggy.gif) I've been on hold with Pertronics for almost 20 minutes. Hopefully I can get through with them soon.
[Re: stumpy]
#800234
09/13/10 05:16 PM
09/13/10 05:16 PM
SeventyGTX
Fallon, Nv
Are you sure you're on the neg side of the coil?
Definitely. Man, Pertronics is impossible to get ahold of with the worst recorded music ever! ![](/ubbthreads/images/graemlins/no.gif)
[Re: SeventyGTX]
#800235
09/13/10 05:31 PM
09/13/10 05:31 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Hey Don. I think when you get ahold of the Pertronics company they may tell you that your going to need a "tach adapter" to work with their ignition system. Just like when i had the MSD system on my old 71 Cuda. It need a tach adapter to work correctly with the factory tachometer. I will bet it's probably the same situation that your going through now. JV.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#800236
09/13/10 05:59 PM
09/13/10 05:59 PM
SeventyGTX
Fallon, Nv
I was wondering about that Jim. I think I have a new MSD tach adapter in the shed I was going to use on the GTX a few years ago, but didn't need it. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
