What oil for Modern Muscle #799719
09/13/10 12:03 AM
09/13/10 12:03 AM
Hunt Valley, Maryland
1fastrunner Offline OP
I have an '09 Hemi Ram and I'm almost ready for my 1st oil change. What oil are you running in your Modern Muscle Motors?
Re: What oil for Modern Muscle [Re: 1fastrunner] #799720
09/13/10 12:06 AM
09/13/10 12:06 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I recomend Amsoil full syn.
Re: What oil for Modern Muscle [Re: moparsquid] #799721
09/13/10 12:09 AM
09/13/10 12:09 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Mobile 1.
Re: What oil for Modern Muscle [Re: 1fastrunner] #799722
09/13/10 12:27 AM
09/13/10 12:27 AM
Texas
Texican Offline
Texican  Offline
Texas
Valvoline Racing
Re: What oil for Modern Muscle [Re: Texican] #799723
09/13/10 04:31 AM
09/13/10 04:31 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Mobile 1 "Clean 5000" 10w30 -- my "modern" muscle is an '04 Hemi with 131K on the odo.
Re: What oil for Modern Muscle [Re: Hotwheelsjr] #799724
09/13/10 05:39 AM
09/13/10 05:39 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a thin grade synthetic. as light as you can go. 5w30 fully synthetic.
what's the owners manual call for?
these new engines have VERY tight tolerances, which is why they burn so clean and efficiently, and last more than 100K miles. so they can get away with much thinner, lighter oils due to the tighter tolerances
**Photobucket sucks**
Re: What oil for Modern Muscle [Re: 70Cuda383] #799725
09/13/10 06:28 AM
09/13/10 06:28 AM
I know I need to go 5 20, but I wasn't sure which brand I wanted to go with. I was leaning toward Mobil 1, but I've been seeing things indicating it's not what it was.
Re: What oil for Modern Muscle [Re: 1fastrunner] #799726
09/13/10 07:28 AM
09/13/10 07:28 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't know, lotta people put too much hype into which brand name of oil they use. I would run any of the name brand synthetic oils if it was mine.
in fact, that's what I DO run in all my modern engines. 0w20 synthetic...the stuff that's in the black bottle, I can't remember who makes it..castrol? my car I've had since new, has 30K miles on it, too new for longevity feedback. my wife's car had 80K on it when she totalled it with a deer's ass, but it was still running like new as well.
I'd like to put 300K miles on my daily driver commuter car, so we'll see how it does.
I think the most important thing is regular oil/filter changes
Re: What oil for Modern Muscle [Re: 70Cuda383] #799727
09/13/10 08:45 AM
09/13/10 08:45 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Any SM-rated 5W20 (or 0W20) will serve you well. Synthetic is just icing on the cake, and allows for extended OCIs.
It's Swifty! Swifty, you toad sucker!
Re: What oil for Modern Muscle [Re: 1fastrunner] #799728
09/14/10 10:14 PM
09/14/10 10:14 PM
VA
Marcus Offline
Marcus  Offline
VA
Try Royal Purple. First oil change in my 2009 SRT8 Challenger picked up 1+ MPG over the factory fill of Mobil 1. Shop around for it; CarQuest here has it on sale $7.49 qt for a case sale. Also think about a catch can for the PCV line-these motors, (5.7 & 6.1) create alot of oil vapor and without the catch can it goes in the intake.
Re: What oil for Modern Muscle [Re: Marcus] #799729
09/14/10 11:24 PM
09/14/10 11:24 PM
IN
ahy Offline
ahy  Offline
IN
I've been running Mobile 1 5W30 in my '06 Hemi Durango. 140k miles and oil consumption is same as new... one quart low after 5,000 - 7,000 miles.
The owners manual calls for 5W20 but I wanted a little more high temp protection if/when I get on it or tow. The MDS seems to work fine with the 5W30.
Re: What oil for Modern Muscle [Re: ahy] #799730
09/15/10 05:36 PM
09/15/10 05:36 PM
fury4speed Offline
fury4speed  Offline
I use Motorcraft 5/20 or 5/30 oil , it is a semi-syn , works well , change oil at 4000 to 5000 miles. Walmart carrys it and is fairly priced.
Re: What oil for Modern Muscle [Re: fury4speed] #799731
09/15/10 07:15 PM
09/15/10 07:15 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
OK everyone, it is MOBIL...Mobile is a city in Alabama.
Re: What oil for Modern Muscle [Re: fury4speed] #799732
09/15/10 07:16 PM
09/15/10 07:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Same here, in my 2010 DD.
Don't be the exception.
Re: What oil for Modern Muscle [Re: Supercuda] #799733
09/15/10 08:29 PM
09/15/10 08:29 PM
I called 2 dealers and they both said they are switching their shop synthetic from Mobil 1 to Pennzoil Platinum. I went to Walmart and 5 qts. of PP was $20 ($4 less than Mobil), so I got the PP.
Re: What oil for Modern Muscle [Re: 1fastrunner] #799734
09/15/10 09:02 PM
09/15/10 09:02 PM
Houma, Louisiana
twister360 Offline
twister360  Offline
Houma, Louisiana
Mobil 1 full synthetic in 2004 Dodge Ram 1500 w/ 5.7 Hemi. 160K miles and no oil consumption.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
