ProSystems 1000hp 4150 carb #798672
09/11/10 03:17 PM
09/11/10 03:17 PM
hartsburg mo
biggerredz71 Offline OP
hartsburg mo
When I rev car up in park air bubbles appear in the front bowl sight glass,Am I sucking air somewere?The car sputters on the top end,When the air bubbles appear it pucks gas out of the front vent tube.Any ideas?Thanks By the way the car is a 70 RoadRunner with a 505,auto trans with a 4200 converter.
Re: ProSystems 1000hp 4150 carb [Re: biggerredz71] #798673
09/11/10 04:10 PM
09/11/10 04:10 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
heat makes bubbles. Where is your gas line run?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ProSystems 1000hp 4150 carb [Re: biggerredz71] #798674
09/11/10 05:08 PM
09/11/10 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your fuel pressure at... the fuel comes in from
the top and sounds like its spraying into the fuel in
the bowl and its aireating
Re: ProSystems 1000hp 4150 carb [Re: MR_P_BODY] #798675
09/11/10 05:18 PM
09/11/10 05:18 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
When the bowl is full the needle and seat barely open so it can't move that much fuel unless it has boost on top of it.
he also has the problem in high gear. thats why i went the heat route. now that i'm typing this i'm thinking air in the fuel line somehow. bad pump, broken fuel pump pickup, bad pickup placement.......
