bolts to fasten motor mounts to k-frame #798636
09/11/10 02:00 PM
09/11/10 02:00 PM
ne ohio
garymendy Offline OP
ne ohio
does anyone know the size/length i need to fasten motor mounts to the k-frame on a 69 charger 440 setup..i don't have the k frame here and can't check it..i would like to be ready with the bolts when i go over to put it in..
thanks!
Re: bolts to fasten motor mounts to k-frame [Re: garymendy] #798637
09/11/10 02:06 PM
09/11/10 02:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
7/16" coarse thread probably about 4" long overall. If you have a mount in your hand you can get a good idea of what you need.
