727 transmission #797663
09/10/10 10:29 AM
09/10/10 10:29 AM
S.E. Wisconsin
darepairman Offline OP
S.E. Wisconsin
I am checking out a 727 tf transmission via E-mail and the guy does not know if its for a small block or big block, what numbers should I tell him to look for that will tell the differance between the two. Thanks Ed
The Event Horizon is on its way
Re: 727 transmission [Re: darepairman] #797664
09/10/10 03:02 PM
09/10/10 03:02 PM
BDW Offline
BDW  Offline
Look up the numbers stamped on the pan rail here:
http://mymopar.com/downloads/transguide.pdf
Re: 727 transmission [Re: BDW] #797665
09/10/10 03:10 PM
09/10/10 03:10 PM
S.E. Wisconsin
S.E. Wisconsin
Thanks man
Re: 727 transmission [Re: darepairman] #797666
09/10/10 04:05 PM
09/10/10 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For a visual check, count the number and size of the lower 4 bolts in the bellhousing.
