powder coat a motor plate #797403
09/09/10 10:50 PM
09/09/10 10:50 PM
Princeton, MN
racingduster Offline OP
Princeton, MN
I wanna powder coat my motor plate. Its on a 400 block. what are your thoughts. I was worried about coolant effecting the powder coat.
Americans will put up with anything provided it doesn't block traffic. - Dan Rather
Re: powder coat a motor plate [Re: racingduster] #797404
09/09/10 10:55 PM
09/09/10 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wont be any different than us that polish them
Re: powder coat a motor plate [Re: racingduster] #797405
09/09/10 11:24 PM
09/09/10 11:24 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It wont be the coolent, but the heat. I painted my motor plate when I painted my car, so far so good
To my knowledge powder coat is more durable than any paint.
Lots of stuff seems to get powder coated. I see intakes, valve covers, brackets.
Seems to last good enough, these parts should see the same temp as the motor plates.
Re: powder coat a motor plate [Re: MR_P_BODY] #797406
09/09/10 11:43 PM
09/09/10 11:43 PM
Princeton, MN
Princeton, MN
Mr_P_body
I understand our an E85 guy is that right?
Re: powder coat a motor plate [Re: racingduster] #797407
09/09/10 11:50 PM
09/09/10 11:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: powder coat a motor plate [Re: MR_P_BODY] #797408
09/10/10 12:15 AM
09/10/10 12:15 AM
Princeton, MN
Princeton, MN
I'm going to have some questions for you soon
Re: powder coat a motor plate [Re: racingduster] #797409
09/10/10 12:22 AM
09/10/10 12:22 AM
Princeton, MN
Princeton, MN
fixed it
Re: powder coat a motor plate [Re: racingduster] #797410
09/10/10 12:29 AM
09/10/10 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good... I see some green plates
Re: powder coat a motor plate [Re: MR_P_BODY] #797411
09/10/10 12:33 AM
09/10/10 12:33 AM
Princeton, MN
Princeton, MN
Yep, dont have a clue what i am doing tho
Re: powder coat a motor plate [Re: racingduster] #797412
09/10/10 12:39 AM
09/10/10 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont worry... there are a FEW on here that do...
between all of us I'm sure you will be set
Re: powder coat a motor plate [Re: Bob_Coomer] #797413
09/10/10 08:00 AM
09/10/10 08:00 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Poweder is baked at around 400* If the coolant gets that hot, you will have more problems then the powder on the motor plate.
Jeff
69 GTX 68 Road Runner
Re: powder coat a motor plate [Re: JERICOGTX] #797414
09/10/10 09:25 AM
09/10/10 09:25 AM
duluth mn.
dragula426 Offline
dragula426  Offline
duluth mn.
for what it's worth, i had a set of elephant ears powder coated for a dart i had, and they leaked...so i just ground off the powder coating at the area where they met up with the block/ pump housing and had no more problems.
Re: powder coat a motor plate [Re: racingduster] #797415
09/10/10 05:24 PM
09/10/10 05:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Well......for starters , the distributor is on the wrong end of the motor.
That is a stout looking bullet.
I will be keeping an eye on his answers too , because E-85 is also in my future.
