Textured dash paint question #797105
09/09/10 12:11 PM
09/09/10 12:11 PM
So Cal
GoManGo70Bee Offline OP
super street
super street
So Cal
I was wondering if you guys will think this will work. I am painting the dash for my 67 Dart Chestnut brown. Since the correct textured factory paint is out of my budget, do you think spraying the color over Rustoleum textured paint as a base will give me something close? My paint shop can mix the brown, no problem but due to Commiefornia, the additive for the texture is no longer available.
Thoughts???
70 Superbee 383 4 speed 70 Hurst 300 67 Dart sedan 74 Ramcharger 03 Hemi Ram 1500 4X4
Re: Textured dash paint question [Re: GoManGo70Bee] #797106
09/09/10 12:16 PM
09/09/10 12:16 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Something to try if you're not trying to do a concourse restoration. Don't reduce the paint as much, you'll get a slight texture that might replicate the factory texture that you're after. Basically you would be spraying a little on the "dry" side. Instead of reducing 50/50, try 55% paint, 45% reducer.
Re: Textured dash paint question [Re: GoManGo70Bee] #797107
09/10/10 01:19 PM
09/10/10 01:19 PM
So Cal
super street
super street
So Cal
All the resto guys on here and no one else has any thoughts on this?
Re: Textured dash paint question [Re: GoManGo70Bee] #797108
09/10/10 02:25 PM
09/10/10 02:25 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
You may want to try this if you are on budget. Rust-oleum Fine Textured Black. # 7220 Black.
Worked pretty well for me. Played around with it a little before I found a technique I was happy with. I'm pleased with the way my Challenger dash turned out.
65 Barracuda
70 Challenger
Re: Textured dash paint question [Re: GoManGo70Bee] #797109
09/10/10 02:31 PM
09/10/10 02:31 PM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
If the Rustoleum isn't catalyzed I wouldn't paint ANYTHING over it.
I've done mine like Dave Watt has suggested. I use flattened catalyzed enamel and dry spray with an HVLP gun. Spray the first coat slick for coverage and then dry spray to the texture you want. Don't forget to spray the glove box door/ashtray etc at the same time so the textures match.
Acrylic lacquer would also work, but I bet you can't buy that in Cali.
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: Textured dash paint question [Re: ramrod] #797110
09/10/10 11:11 PM
09/10/10 11:11 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Very dry, lots of gun distance, under-reduced but not quite to the point where it comes out of the gun like spaghetti. Experiment with air pressure so it doesn't lay down or flow out. Probably use a "hot" reducer. You kind of "fog" it on. Mixing in flattening-agent in paste form will help, not only for dullness but sometimes rougher texture. Experiment, experiment, before you paint. Painting all the suede parts at the same time as suggested is a very good idea.
Re: Textured dash paint question [Re: jrwoodjoe] #797111
09/10/10 11:16 PM
09/10/10 11:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy used Rust-oleum Fine Textured Black on his 68 Dart dash after I used the Rust-oleum Fine Textured Grey on my Minilite look-a-like rims.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Textured dash paint question [Re: autoxcuda] #797112
09/14/10 01:26 AM
09/14/10 01:26 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I just use single stage paint and mix in a flattening agent. I bought a quart and use it for all kinds of stuff. You have to do a couple of tests until you figure out how much flattening you need.
The one I use is Dupont 4531S
If you get the amount correct it gives your paint the same texture as the factory suede paint.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Textured dash paint question [Re: GoManGo70Bee] #797113
09/15/10 05:27 PM
09/15/10 05:27 PM
So Cal
super street
super street
So Cal
Thanks for all the advice!! I finished it today and it came out great!!!! Nice even suede texture and perfect color!!
Heres what I did. After trying several methods, heres what worked best.
Used Valspar paint, matched to a OEM color chip.
Paint guy made it nice and flat.
Mixed it 1:1 at first.
Layed down several nice coats to get a nice dark color.
Then mixed about 1.5:1 and fogged it several times. This gave it perfect texture but would wipe off cause it was sprayed so dry, so, next I went back to 1:1 and layed down one more coat to lock it in.
After it cured overnight, nice texture and it is very durable.
Thanks for all the help again!!!
Now to reassemble dash!!!
Re: Textured dash paint question [Re: GoManGo70Bee] #797114
09/15/10 05:31 PM
09/15/10 05:31 PM
So Cal
super street
super street
So Cal
Oh yeah, and BTW, cost......31 bucks for a quart vs 125/quart for "correct" paint.
Re: Textured dash paint question [Re: GoManGo70Bee] #797115
09/15/10 06:01 PM
09/15/10 06:01 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
I'm finishing up a 1970 E-body column for a member now. I have a local paint store that still has the original lacquer DDL formula. Took a couple of tries on my end to get the texture to where I feel is right . But once done it looks GREAT
Enjoy life today, It has an expiration date
