727 Not Down Shifting from a stop #796722
09/08/10 11:04 PM
09/08/10 11:04 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
I had my radiator re-cored ,installed it, topped off the tranny with fluid. Took car out for a little test drive. Decided to do a burn out ,thru 1st and 2nd . Came up to the stop sign and when I took off it acted like it was still in drive. Tried it a couple more times from a dead stop and it does the same thing. Although it shifts fine when you manually shift it from 1st thru drive. What could be the problem ?.
Re: 727 Not Down Shifting from a stop [Re: 493RT] #796723
09/09/10 12:14 AM
09/09/10 12:14 AM
scratchnfotraction Offline
overrunning clutch(sprag)
just guessing,as i dont know how to fix them,just tear them up and change them
but i have had that before and it was not good,hear any noise when pulling off in drive?
not wanting to work,pull it down to 1st and it grabs and goes? shifts fine manual shifting,up and down?
got one on the shop floor like that myself,works but makes noise when i forgot to manual shift it after a stop but works when shifting it up or down just no auto function
Re: 727 Not Down Shifting from a stop [Re: 493RT] #796724
09/09/10 01:56 AM
09/09/10 01:56 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
One of the Governor weights is sticking. I had that happen lots years ago when I was sometimes too lazy to go thru the governor support and weights on a quick rebuild.Not anymore!
You might be able to get the extension housing off and take the weights out and use some crocus cloth to clean them up.Then flush with a cleaner.
Definitely a "debris" issue though.
Re: 727 Not Down Shifting from a stop [Re: superwrench] #796725
09/09/10 03:10 AM
09/09/10 03:10 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Yep. Cleaning or replacing the governor should fix it, at least temporarily. Sometimes a governor problem is a sign of other more major problems. Metal pieces can circulate and lock up governor weights.
Re: 727 Not Down Shifting from a stop [Re: Ramrod39] #796726
09/09/10 10:49 AM
09/09/10 10:49 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
3rd vote on the governor. Get an A&A gov weight while your at it, just pick your RPM and leave it in drive - best thing since sliced bread
Re: 727 Not Down Shifting from a stop [Re: BergmanAutoCraft] #796727
09/09/10 01:55 PM
09/09/10 01:55 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Thanks guys, I will check that out.
Re: 727 Not Down Shifting from a stop [Re: 493RT] #796728
09/09/10 03:07 PM
09/09/10 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before tearing into anything but a pressure gauge on the governor test port, anything over 2 psi at a standstill in Drive is a governor problem.
If the pressure is OK look for a stuck shift valve in the valve body.
