Can't get brake line pressure #796667
09/08/10 10:15 PM
09/08/10 10:15 PM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Guys,
I am trying to bleed the brakes on the 56 Coronet and can't get any line pressure at the brake cylinders (rear) or the calipers (front). The car has front discs from fat man with new master cylinder from tuff stuff I think. I bled the cylinder before hooking the lines up, but for some reason it doesn't put any prssure to the brakes. The discs aren't even pushing against the rotor. What am I missing here? I have fluid to the rotors, and the master cylinder rod is pushed in a few inches when the brake peddle is pushed.
Should I go back and bleed the master cylinder again? I have a summit prop valve and new brake lines as well.
Re: Can't get brake line pressure [Re: moposcar] #796668
09/09/10 08:49 AM
09/09/10 08:49 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Where to start....
When you bench bled the master, was it delivering good fluid flow from both ports?
Does the master cylinder return all the way back when the pedal is released? If the master is not returning fully, it can not refill the cylinder because the port is still blocked.
Be sure there are no leaks. The current supply of new fittings, hose connections, and lines don't seem to seat as well as the ones from a couple years ago did, you really need to crank the new ones tight. Recheck every connection, look for even the slightest wetness.
Is all the air out of the lines? These days, bleeding brakes has become a pita.
Unfortunately, these days, "new parts" does not mean the parts are good. Lots of defective new stuff out there.
If all else fails, you will need to check brake pressure at each connection to find out where you are loosing the pressure. Good brake parts will force a finger off the fitting under pressure, if you can seal a fitting with your finger, you have located the problem. You will need to start at the master.
Gene
Re: Can't get brake line pressure [Re: poorboy] #796669
09/09/10 09:46 AM
09/09/10 09:46 AM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Gene,
Thanks for the reply. I woke up this morning and remembered that the brakes were always spongy. They never hardened up and built up pressure. I don't know if that helps or not.
The bench bleed had good flow coming from the lines, however like you said I had to tighten the crap out of the lines to keep them from leaking and there is a leak somewhere at both new calipers b/c it pealed the paint on them. I was letting them gravity flow out to get fluid in the lines initially and noticed the leaks.
Looks like I have my work cut out.
Re: Can't get brake line pressure [Re: moposcar] #796670
09/09/10 10:06 PM
09/09/10 10:06 PM
Freeport IL USA
Freeport IL USA
Gotta start by sealing up the leaks. Any tiny leak will give a spongy pedal and/or no pressure.
I'm old enough to remember when a guy could make some money doing brakes, usually quick and easy, but like so much stuff, those days are gone. Gene
Re: Can't get brake line pressure [Re: poorboy] #796671
09/15/10 02:20 AM
09/15/10 02:20 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
is your master cyl on the fire wall or under the floor???
if under the floor,,you need residual valves to hold line pressure since the calipers are now higher then the resoviour,,,( MASTER )
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Can't get brake line pressure [Re: fstfish66] #796672
09/16/10 09:42 AM
09/16/10 09:42 AM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
My master cylinder is up on the firewall.
I pulled the front wheels off to get a good look at everything, ran down all the leaks, polished the fittings where I had leaks. Then I noticed my bleeder screws on the front discs were on the bottom....I put them there to keep mud/dirt from caking in them. I thought to myself...you dummy, air won't go down to the bottom of a caliper reservoir. So I switched th calipers around to get the bleeder screws on top, and then I really noticed how bad the leaks were. The bolt with the brass washers that threads into the calipers was leaking. I tightend the shiznit out of them and they still leaked.
So when the car went to the front end alignment shop, I asked him to finish them for me. Tired of beating my head on it and have too many other projects to finish.
Thanks for all the replies. Figured you guys would like to hear about the bleeder screws on bottom...the little things sometimes.
Re: Can't get brake line pressure [Re: moposcar] #796673
09/16/10 10:57 AM
09/16/10 10:57 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
usually,,those brass washers on the calipers cant be reused,,,and most require 2 washers one on each side of the hose fitting,,,
so it would be bolt,washer,hose end,washer in to caliper,,, let us know how you made out
2015 cherokee
2013 R/T classic
Re: Can't get brake line pressure [Re: fstfish66] #796674
09/17/10 07:08 PM
09/17/10 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've noticed that reman calipers come with new washers that are too thin to work, the rifle drilled bolt bottoms out well before the washers seal. PepBoys used to carry a selection of copper sealing washers.
Don't be the exception.
Re: Can't get brake line pressure [Re: Supercuda] #796675
09/18/10 05:22 PM
09/18/10 05:22 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Don't feel to bad about putting the calipers on the wrong side [ bleeder on the bottom ] seen it on here a number of times, your right , it's hard to bleed the air out down. Normally need to get new washers each time there removed, most auto parts stores have them.
Re: Can't get brake line pressure [Re: rowin4] #796676
09/18/10 07:51 PM
09/18/10 07:51 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I would like to see pics of the car ?
Whats the chance of that ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
