points gap #796486
09/08/10 07:42 PM
09/08/10 07:42 PM
appleton,wis
moparrookie Offline OP
appleton,wis
my brother is finishing a super b with a 440 and insists on staying with points. Does anyone know the points gap?
Re: points gap [Re: moparrookie] #796487
09/08/10 07:58 PM
09/08/10 07:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.015 to.017
Re: points gap [Re: DAYCLONA] #796488
09/08/10 08:41 PM
09/08/10 08:41 PM
appleton,wis
appleton,wis
thanks
Re: points gap [Re: moparrookie] #796489
09/08/10 09:08 PM
09/08/10 09:08 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Im showing .014-.019 gap with dwell at 28 to 33 degrees
Re: points gap [Re: R/T1968R/T] #796490
09/08/10 09:51 PM
09/08/10 09:51 PM
Point gap does not have to be set to (published) specs. You can set it anywhere. The smallest gap will give the longest dwell which'll give the hottest spark (more time for coil saturation) but make the points burn up faster cause they're closed longer so more time for current to pass & eventually burn them so granny would want a short dwell time and a hot rodder the opposite. Could even start w a .010" gap & if it'll start it'll give him the hottest spark. No start bump it up to .012".
Re: points gap [Re: RapidRobert] #796491
09/08/10 10:54 PM
09/08/10 10:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Keep in mind..
That as the rubbing block wears, the gap decreases..
Thats why it is best to set them on the wider(higher) side to start with.
Just my $0.02..
Re: points gap [Re: Sinitro] #796492
09/08/10 11:42 PM
09/08/10 11:42 PM
scratchnfotraction Offline
I am like your bro,run points on all of mine
but then again,a pertronix points conversion will be an upgrade and still retain the better vac advance curve a points dizzy has over a smogger elect dizzy
old skool can still be made to work in todays world :whistling
just not as bling IMO
I gut a stock BR and use a strand #10 wire solderd in to by pass the BR to give the pertronix a full 12 volts with their 40,000 volt flame thrower coil
very covert unless you know what to look for
