I run a ss spring car with a transbrake. car weights 3000 without me [270], I run 8lb of air in the rear running 14x32s. I put the brake in over the winter and leave on the two step at 3000rpm. I run spring clamps 3 on the right 2 on the left as per shawn jennings websight. I was thinking of staggering air pressure or mabe investing in some rancho adjustable shocks. the car pulls the front end about 6 to 12 inches on the launch with no frame twist. After launch car goes straight and true. Any input?
