Re: new slick ???
[Re: earthmover]
#796178
09/08/10 01:54 PM
09/08/10 01:54 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
What you have to look at with gears is the powerband. Think about this the 5.13 gear means that the driveshaft will turn 51.3 times for every 10 revolutions of the ring gear. So really you are just turning the motor harder not the tires. If your peak power is at 5500rpm or so then more gears will not help. What does your converter flash too?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: new slick ???
[Re: earthmover]
#796180
09/08/10 03:06 PM
09/08/10 03:06 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
well with a 29.5 slick and 5.13 gears look at trapping 6600 and if you gain some performance 6700 to 6800. I would advance the cam you have now to 104 or 103 and you should see a significant improvement. If you install the bigger cam try it at 102 right off the bat!
Re: new slick ???
[Re: Dodgem]
#796183
09/08/10 04:30 PM
09/08/10 04:30 PM
Posts: 2,449 nc
earthmover
nc
There should be some in a bigger cam degreed right. more gear always helps if you are not afraid of rpms. you may be fighting the flow on your heads as a big limiting factor so maybe a set of aluminum CNC'd are in order (plus they take 50 lb off the front end!!!)
. Yea I know some more heads will do it just want to use what I have now . I gotta get started on my sons car for next year 72 dart big block stroker . So I want to max out what I have now . The tires I can use either way thanks
Re: new slick ???
[Re: Dodgem]
#796186
09/09/10 01:29 AM
09/09/10 01:29 AM
Posts: 2,449 nc
earthmover
nc
