Going from 4.10 to 4.30 how much RPM #795881
09/08/10 12:20 AM
09/08/10 12:20 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I bought a DANA 60 w/4.30 gears last year how much rpm difference at the stripe ....I hear about 300rpm ...what do you guys think?
Specs 440 eagle rods
275 60 15 Drag Rad.
8"ATI CONVERT
WITH 4.10 I was going thru @ 6600 6700
Re: Going from 4.10 to 4.30 how much RPM [Re: 10secGTX] #795882
09/08/10 12:31 AM
09/08/10 12:31 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
275 60 15 Drag Rad.
8"ATI CONVERT
Your correct the difference will be about 300 RPM, mike
Re: Going from 4.10 to 4.30 how much RPM [Re: 10secGTX] #795883
09/08/10 12:42 AM
09/08/10 12:42 AM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
If you don't change anything else, the Moroso power/speed calculator says 325 rpm. So yes it should be 300-400 rpm different.
I went the other way before from 4:56 to 4:30 and the rpm droped 400.
Hope this helps
Re: Going from 4.10 to 4.30 how much RPM [Re: mopar_to_ya] #795884
09/08/10 01:22 AM
09/08/10 01:22 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
dont mean to Hijack...what about from 4.56 to 4.10?
Re: Going from 4.10 to 4.30 how much RPM [Re: 70blackfish] #795885
09/08/10 06:39 PM
09/08/10 06:39 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
GO TO
Wallace calculators
You can find the gear calc... enter your variables & print out a nice chart.... Did that when I went to 4.88's from 5.13's. Picked up 5mph.....now considering 4.56's
V10
Re: Going from 4.10 to 4.30 how much RPM [Re: 70blackfish] #795886
09/08/10 06:45 PM
09/08/10 06:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
around 670 rpm, mike
Re: Going from 4.10 to 4.30 how much RPM [Re: Sport440] #795887
09/08/10 08:54 PM
09/08/10 08:54 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I went from 4.30 to 4.10 it was about 200 rpm did,t make no diff in the et slip
Re: Going from 4.10 to 4.30 how much RPM [Re: VernMotor] #795888
09/08/10 09:43 PM
09/08/10 09:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its probably important to Note. That similer rpm changes can be had by different tire diameters.
With 3.91,s and a 27.3" tire and swapping to a 26" tire the mathmatical RPM difference is 306 RPM between the two different tire Diameters.
My car was faster with the taller tire and less RPM. Even though the 26" tire had More gear leverage.
Theres a "Sweet spot" with everything, combined in the "Combo"
And Were All never done, looking for them to all match up, mike
Re: Going from 4.10 to 4.30 how much RPM [Re: 10secGTX] #795889
09/09/10 12:09 AM
09/09/10 12:09 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Going from 4.10 to 4.30 how much RPM?
Really? Need a calculator?
The answer is still the same as it was the last 500 times: new ratio ÷ old ratio. In this case 4.88%, for 6,600 it's 322 RPM.
The are almost no relationships in cars that are anything but a direct comparison just like that (and most people get the others wrong anyway).
Boffin Emeritus
Re: Going from 4.10 to 4.30 how much RPM [Re: polyspheric] #795890
09/09/10 02:03 AM
09/09/10 02:03 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Im missing some of your math,
the 322 RPM is right.
the 4.88% is right
but the new ratio/ by the old = 1.0487804878
Okay, I see the .0487804878 part in the equation,
So if you lose the 1. move the decimal two points I see the 4.878 But thats not the way to get to 4.88%
How does one divide the new ratio from the old without a calc. mike At 1.01 am and Im a head, mike
Re: Going from 4.10 to 4.30 how much RPM [Re: 10secGTX] #795891
09/09/10 03:38 AM
09/09/10 03:38 AM
Cab_Burge Online work
Cab_Burge  Online Work
275 60 15 Drag Rad.
8"ATI CONVERT
I see a lot of responces concerning the math, you have to remember that if you make the 1st and 2nd gear changes at the same RPM with both rear gear ratio you will be further down the track with the 4;10 than you where with the 4;30 so the RPM drop(EDIT: at the finish line) will not be as calculated due to the car going into high gear with the 4:10 further down the track. It won't spend as much time in high gear so it won't accelerate as fast as it does in high gear as it did with the 4:30 Don't be surprised to see very little ET and MPH changes with that ratio change Do the change it may go quicker and faster, not much probally, but some
Re: Going from 4.10 to 4.30 how much RPM [Re: Cab_Burge] #795892
09/09/10 10:28 AM
09/09/10 10:28 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
First ..Thanks for the info,I just wanna keep the car sunny side up and no windows in my block. Looking forward to the Classic at Norwalk
Re: Going from 4.10 to 4.30 how much RPM [Re: 10secGTX] #795893
09/09/10 10:47 AM
09/09/10 10:47 AM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
So does anyone know where to get 4.30 PRO gears for a Dana 60? I can't seem to find any available, and .56's are more than I want.
Sorry for the hijack!
Re: Going from 4.10 to 4.30 how much RPM [Re: Cab_Burge] #795894
09/09/10 11:05 AM
09/09/10 11:05 AM
New York
polyspheric Offline
polyspheric  Offline
New York
This is true - the math is simple, but the results are confusing. If the engine turns too fast with the 4.30 the MPH will go down even more, etc.
How do you do it without a calculator?
Uh.... the way you did in school, for the last 2,500 years?
Boffin Emeritus
Re: Going from 4.10 to 4.30 how much RPM [Re: polyspheric] #795895
09/09/10 01:36 PM
09/09/10 01:36 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Going from 4.10 to 4.30 how much RPM [Re: ETASPEN] #795896
09/09/10 03:00 PM
09/09/10 03:00 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
member Doctor Diff I think has them available...
This space available for rent
Re: Going from 4.10 to 4.30 how much RPM [Re: polyspheric] #795897
09/09/10 03:39 PM
09/09/10 03:39 PM
I have been taught that math occurred in or around 3000 BC, 3000 BC and 2010 equal 5010, not 25000 years ago I'm not a PHD in math so maybe my math is inaccurate As in all things scientific, especially racing, not all theory are accurate or valid until tested and verified
Re: Going from 4.10 to 4.30 how much RPM [Re: VernMotor] #795898
09/09/10 06:13 PM
09/09/10 06:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
glad to see that, i did the same thing just for better street manors,havnt taken it to the trak.
Re: Going from 4.10 to 4.30 how much RPM [Re: bonefish] #795899
09/10/10 01:25 AM
09/10/10 01:25 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Fran likes bringing out the scholars in everything he is active in. No fighting, guys. He was just asking opinions. He got it in the first 3 posts. I'm sure he is very thankful for the rest of the info. Carry on/ Fran, I say 10 40's, no cage, Vic driving YOUR car..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Going from 4.10 to 4.30 how much RPM [Re: sunroofgtx] #795900
09/10/10 10:08 AM
09/10/10 10:08 AM
cptn60 Offline
cptn60  Offline
Nice summary. When did you become a moderator?
