'66 Plymouth B-body rear wheel width with mini-tubs
#795293
09/07/10 09:04 AM
09/07/10 09:04 AM
Posts: 243 Helsinki, Finland
Anselmi
Helsinki, Finland
What rear wheel width/backspace are you using in a 1966-67 Plymouth B-body with mini-tubbed (ie inner wheelhouse moved next to rear frame rail) wheel wells? Pics?
Looking for "factory" steel wheels, Wheel Vintiques has 15x10 with 5.5" backspace. Is that enough backspace?
'66 Plymouth '64 Dodge '63 Plymouth x 3
Re: '66 Plymouth B-body rear wheel width with mini-tubs
[Re: StealthWedge67]
#795295
09/08/10 12:20 AM
09/08/10 12:20 AM
Posts: 1,090 Saskatchewan, Canada
barracudabob
I have a '66 Satellite. I minitubbed it to the frame rails, and used a 15X10 Weld Draglite with 7 1/2" backspace. Its tight in there, but I can run a 29 X11.5 tire. I have since changed the 8 3/4 to a Dana. I narrowed it four inches on each side and use a rim with 3 1/2" BS. Hope this helps. Bob
[Re: rapom]
#795297
09/10/10 06:14 PM
09/10/10 06:14 PM
Posts: 1,883 Northern OH
rapom
Northern OH
