383 board 30 over #795002
09/06/10 10:52 PM
09/06/10 10:52 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
i was wondering what my hp might be with a 1965 383 board 30 over runnig stock heads/ any info?
Re: 383 board 30 over [Re: paulyvault] #795003
09/06/10 10:55 PM
09/06/10 10:55 PM
IN
ahy Offline
ahy  Offline
IN
It depends a lot on the compression ratio and camshaft. Exhaust and manifold/carb matter also. Can you post a bit more info?
Re: 383 board 30 over [Re: ahy] #795004
09/06/10 11:01 PM
09/06/10 11:01 PM
ca, slo.
P
P
ca, slo.
got a 780 carb i believe, with full lenght headers, i dont think the cam is anything special, im tareing down for a rebuild and i was just wondering , thanks
Re: 383 board 30 over [Re: paulyvault] #795005
09/06/10 11:14 PM
09/06/10 11:14 PM
IN
ahy Offline
ahy  Offline
IN
The old goal of a basic performance build is 1 HP/cu in. That would be possible on a iron head 383 if you can get compression to around 9.5 with a moderatly aggressive cam. Rebuilt to stock specs, I guess HP would be in the high 200's.
A '65 likley has close chamber heads (what casting number or cc are the heads?) which makes getting 9.5 CR more doable. Usually getting the cr dialed in on a big bore/short stroke engine like the 383 is tough.
Re: 383 board 30 over [Re: ahy] #795006
09/06/10 11:42 PM
09/06/10 11:42 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
What pistons are you running??
Most pistons today sit down in the hole more than the originals and dropping the compression ratio.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
