4 barrel intake swap #794227
09/06/10 09:28 AM
09/06/10 09:28 AM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Can I put an Edelbrock LD340 intake on my 1985 dodge w150 that has factory air conditioning? I dont want to tear it all apart and find out that it wont fit.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 4 barrel intake swap [Re: 73cuda340] #794228
09/06/10 10:04 AM
09/06/10 10:04 AM
Toronto Ontario
Butt Ugly Offline
Butt Ugly  Offline
Toronto Ontario
It will not work!!!!!!!!
Send me offending manifold and save yourself the aggravation trying to make it work
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: 4 barrel intake swap [Re: Butt Ugly] #794229
09/06/10 10:34 AM
09/06/10 10:34 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Depending on which ac you have (don't remember when the pump switch was made) the LD340 will work with the older AC bracket. It is drilled and tapped for AC.
Re: 4 barrel intake swap [Re: MoparforLife] #794230
09/06/10 11:07 AM
09/06/10 11:07 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
I have that intake on my 360 and love it.
Re: 4 barrel intake swap [Re: 73cuda340] #794231
09/06/10 12:29 PM
09/06/10 12:29 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
No it won't fit, you can run a torker II, standard performer, make a custom bracket for the compressor or take the A/C off- I ran into this on my 86 when I swapped in a 360 with an RPM Air gap, I had a performer on the 318 that was in it before and the A/C fit fine.
