Did '72 Charger's Have Under Steering Column Trim Piece #794179
09/06/10 03:23 AM
09/06/10 03:23 AM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
Did 1972 Chargers have an under the steering column trim piece? Mine does not have one, and it just doesn't look right without it. I have looked through the service manual but I cant seem to find a picture showing one. If so would anyone happen to have a picture of one?
Thanks, Reid.
Re: Did '72 Charger's Have Under Steering Column Trim Piece [Re: Moparguy383] #794180
09/06/10 04:01 AM
09/06/10 04:01 AM
USA
dodge_nut Offline
dodge_nut  Offline
USA
are you referring to the piece that hides the wires on the bottom of the column and in between the 4 mounting holes? if so, then yes, they all had them.
Re: Did '72 Charger's Have Under Steering Column Trim Piece [Re: Moparguy383] #794181
09/06/10 08:01 AM
09/06/10 08:01 AM
ne
broncobra Offline
broncobra  Offline
ne
I seriously don't remember one. I was fanatical about keeping it as original as possible. I was underneath for stereo sutff and even swapping the entire gauge cluster out to have a factory dash with tach, and had the connector melting problems, and taking out the buddy jump seat and putting a slapstick console in. I really just don't remember taking a cover off, and that would have been the first thing. My Bronco has one.
Re: Did '72 Charger's Have Under Steering Column Trim Piece [Re: Moparguy383] #794182
09/06/10 09:58 AM
09/06/10 09:58 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Nope. My original '72 does not.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
