Re: Who's not going to Norwalk-[me]
[Re: VIPERDUST]
#793991
09/06/10 01:23 AM
09/06/10 01:23 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
Sorry to hear that Matt, the car was working good too!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: dvw]
#793996
09/06/10 08:47 PM
09/06/10 08:47 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The head is no problem at all and the block can be welded with nickel rod. The guy that fixed mine welded it up in the car after I wrapped keo wool in the cylinders and laid fire proof fiberglass cloth on the deck surface. He said he would charge me 100.00 for both the head and block but wanted to know how I would surface the block after welding it up. I told him you could carefully file it down taking your time and get it with in .004 and the gasket would seal. The next day he called and not only was it welded he said he had to try filing it down by hand. It was under .003 across the weld and he was very happy. He ended up charging me 80.00 because he said he learned something. Burnt it up on a Sunday,ready to go again on Thursday thanks to his ability. I still have the block if you need pictures of this 440 block I still have it and it never blew a head gasket again.
[Re: moparbrown14]
#793999
09/07/10 12:42 AM
09/07/10 12:42 AM
Posts: 374 kalamazoo, MI.
VIPERDUST
kalamazoo, MI.
No juice, At the Nittro Jam at Martin a couple weeks ago. Best it ran this year was 11.12 @118, and when the hot summer hit, was running 11.24 to 11.28. I think it happened when warming the car up sat. wound it up in 2nd, and grabbed 3rd, and it just acted funny, like it loaded up. I thought something was wiered, but couldn't put my finger on it. Was idleing different, then when I did the burn box, was under powered. Launched from the line, and it just laid down.I have been on barrowed time with the motor. It was build in 06, and not freshened. I guess a set of fresh head gaskets might of prevented this..Matt... I believe the gaskets were the felpro 1008
