If thats straight 30 weight with a drill, you put 20w/50 in it and give it some throttle it will peg the gauge fact. If anyone here has exploded a oil filter like me they can tell you what a horrifying experience it is.
Dont start that engine like that, foolish advice
Anything over 60-70 psi is counter productive, robs lots of power, oil is in constaint bypass, adding heat and this how people ring the intermedate shafts into.
Cut about a 1/8th inch off the spring, and retest it by priming. Priming the system will give you a ball park figure of idle oil pressure, using the same oil. You would see 10-15 more psi just by changing oil weights from 30w to 20w/50 etc.
Get the pressure down around 60 psi with the drill and the same oil you plan to run
Hope this helps
