6.1 Hemi conversions??
#79131
06/24/08 11:18 AM
06/24/08 11:18 AM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
I'm seriously thinking of putting in the new MP 6.1 crate kit. Anybody here who has done this conversion that can give tips/hints? My specific application is; '71 Road Runner, Keisler 5spd., 8 3/4 rear, AlterKtion front suspension and rear coil over AirRide setup, 4-wheel disc brakes w/Hydroboost. Here is other conversation on this topic; https://board.moparts.org/ubbthreads/show...part=1&vc=1Thanks!!!
Re: 6.1 Hemi conversions??
[Re: Fasbird]
#79132
06/24/08 02:41 PM
06/24/08 02:41 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
what would you like to know? are you going injection or carb?
i have put alot of thoughts into the swap prior to my own swap.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: 808CUDA]
#79135
06/24/08 07:23 PM
06/24/08 07:23 PM
gremlinsteve
houston texas
the write up that 808 did should be able to cover most if not all the questions. witht he gearbox choice the injection is fairly easy. no kickdown linkage to worry about.
let me know if you need any thing else answered..
steev
[Re: hemibeep]
#79138
06/25/08 06:18 AM
06/25/08 06:18 AM
Fasbird
The Dark Side
That sounds cool Hemibeep. This is the number that was given of the throttle body that comes on the engine. P5153689.... Throttle body From what I gather, the installer has to have a custom cable made. Anyone out there have a source for this cable? I have also decided on using the TTI headers. Here is another source for conversion parts. I will be calling to see what a fuel tank system and radiator setup will run me. I'll pass on any info I get. I will also be documenting this install like 808 did for his Cuda'. http://www.henrycorods.com/index.html
[Re: hemibeep]
#79140
06/26/08 03:16 AM
06/26/08 03:16 AM
808CUDA
I am thinking about stepping up on the cam, based on how mellow 808 said his motor sounded.
Yep, if you really want to get an aggressive exhaust note at idle, you will need to get a cam with a tighter LSA. I did not want to change any of the OE driveability aspect at this time, so I left it stock. Besides, it makes plenty for the missus Left stock it would make a great sleeper in an A-body. Sounds like a 318 with ana exhaust
[Re: DaveKanofsky]
#79143
06/27/08 01:07 PM
06/27/08 01:07 PM
Fasbird
The Dark Side
Thanks Dave.
OK guys, how about specific part/part number, or manufacturer recommendations for aluminum radiators, shrouds, electric fan modules, fuel tanks, pumps (whether to mount the fuel pump internally or externally), rear sump oil pan and pickup, etc., etc.
[Re: Fasbird]
#79144
06/28/08 11:25 AM
06/28/08 11:25 AM
Posts: 279 Pacific Northwest
Weldtech
Pacific Northwest
Hi Guys
We have just finished making a pan for aftermarket suspensions such as the Alterktion, XV (We made their original pans) and Magnumforce. We also have a version for ones with a stroker crank like in the 426 version. They feature the same one piece flange and G machine baffle.
Price is $395.00 with pickup and $425.00 for the stroker mod. I will get a photo or 2 soon.
www.weldtechstainless.com
Where NOTHING is made in China!
70 Challenger drop top 440 4 speed R/T clone (Re-creation, Tribute, Fake, whatever...)
[Re: Fasbird]
#79148
06/29/08 04:59 PM
06/29/08 04:59 PM
808CUDA
808cuda,
Awesome post about your install. I see your last post on the install was nov/07. Any new info you can share. What was your approximate cost of the radiator setup. Sure looks nice. I made my purchase yesterday. Got the 6.1 MP kit and TTI's for the exhaust. I will have to order the bellhousing/clutch/flywheel setup today from Keisler.
Any other feedback or tips would be great. Thanks for the informative post. Now, all I have to do is figure out which way to go with the oil pan dynamics.
Any update on you hooking up the A/C yet?
Thanks!
Fasbird, sorry for the late post reply.
The radiator costed $1200 (rad/custom fan/shroud/wiring/sensorkit).
I have to update my post. Ever since I got her running, cannot stop my self to finish the finer details such as hiding some loose wiring, plumbing the a/c lines, etc. The car is so much fun to drive!
I was just out with some friend's last night and had a blast with the car. Everybody with an ole skool engine was having small issues like, leaking valve cover, overheating at idle, charging problems... so nice to be able to just buzz along worry free
you can check the radiator out at rondavisradiators.com
If you need anything else, let me know
Gil
[Re: 808CUDA]
#79149
06/30/08 09:31 AM
06/30/08 09:31 AM
Posts: 320 Clinton Twp. MI.
ChargerDude70
super street
super street
Clinton Twp. MI.
This is a pic of the 5.7 in my dart we did last year. I just finished the change over to a 6.1L. I put a Tomahawk cam it it as well as a 5 angle valve job. Runs like a raped ape. Very happy with it. Custom rad: $340.00 Junk yard fan: $20.00 SPAL fan controller: $90.00 Total: $450.00
DODGE...Devistation On Driving Grounds Everywhere
69 Dart Swinger 6.1 Hemi 4-Spd
70 Charger R/T B3/B5 6.1 Hemi Auto
76 Coronet
2008 H.D. Street Glide Aniversary Model 821 of 3000
2011 Challenger R/T T.O. 6spd
