Engine Guru's- What does this spark plug tell you?
#791200
09/02/10 10:02 PM
09/02/10 10:02 PM
Posts: 386 Maryland
reno340
Maryland
I have noticed that I still have a bit of a problem w/ #8 cylinder firing. It misses when cold and seams to run fine when the engine is warmed up. I did have a problem w/ that cylender firing in the past but it improved when I put in an older autolite spark plug to replace a new Bosh platinum plug that did not seem to fire on that cylender. I have run it (only in the garage as car not on the road) for about 6 months of weekly starts and 1/2 hour time at idle w/ some revs. Here is a pic of that plug. For any history on the problem in that cylender I refer you to this post https://board.moparts.org/ubbthreads/show...&PHPSESSID=BTW, You can't tell from the pic but the plug is wet and smells like gas even though last I had it running was about 1-2 days ago.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Engine Guru's- What does this spark plug tell you?
[Re: reno340]
#791201
09/02/10 10:12 PM
09/02/10 10:12 PM
Posts: 386 Maryland
reno340
Maryland
[Re: Cudajon]
#791205
09/02/10 10:54 PM
09/02/10 10:54 PM
Posts: 386 Maryland
reno340
Maryland
I don't know about the valve seals. had the car since 1991 but never had it on the road.
[Re: ditchdrift]
#791208
09/03/10 01:44 AM
09/03/10 01:44 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Also make sure the PCV system is all good, a good test is while its idleing, pull the PCV valve out of the VC & put your finger over it, the RPMs should drop & you'll feel a strong suction, if you don't, you need to fix it if its blocked somewhere, if its not, a weak signal here indicates weak rings. It is also very possible its the seals are gone & the guides are badly worn.
[Re: joedust451]
#791209
09/03/10 08:35 AM
09/03/10 08:35 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I didnt get back to that thread but if you swapped wires and plugs and it looks like that and still misses, you more than likely have a mechanical problem in that cylinder. Do a compression test on the engine and report the findings. If it was me at this point, I'd be pulling the head just to see what's going on.
