Re: Chrome ignition box or orange?
[Re: RapidRobert]
#790469
09/04/10 12:26 AM
09/04/10 12:26 AM
Posts: 580 PA
Moparzrule
PA
And that's probably because they were in the distributor with the heat and what's the chance they put the paste underneath when they replaced it. I have the hei on one car and plan on adding it to another but Once the wiring is in place they are an easy replacement if they do fail and they are cheap. You can run a hotter coil too. If it's good enough for the Renault Lecar, it's good enough for me.
My Own Personal Adrenaline Rush
[Re: '84 D150 Shorty]
#790470
09/04/10 12:35 AM
09/04/10 12:35 AM
Posts: 1,822 Colorado
denfireguy
Colorado
it smoothed out the idle, makes for crisper acceleration,
I wanna try an E coil w & wo the HEI module to see which is making the most difference. What is the white "thermal paste"? It's gotta be better than the dielectric grease I was using and the small capsule that come w those modules has the white paste. I didn't have any probs but I'm paranoid about (ign) breakdowns and anything I can do ahead of time to better my odds...
Not sure what the white paste is made of, all I know is it helps to transfer the heat the heat sinc, so your module won't fry. As to which component is helping the most, I think its 50/50. The module is has better capabilities, especially in higher RPM's, and the coil fires hotter, so together...KABLAM
The white paste is a silicon compound that promotes heat transfer. It is also called heat sink compound or grease used in electronics for mounting high power transistors to heat sinks. Radio Shack stores have it. Look up 276-1372. I know of no difference between the white and clear compounds. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#790472
09/04/10 12:51 AM
09/04/10 12:51 AM
RapidRobert
thanks Craig, That's what I was looking for, I'll give em a call. I want the white paste
[Re: Moparzrule]
#790473
09/04/10 01:08 AM
09/04/10 01:08 AM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
Uhg....the name Renault makes me wanna set myself on fire...
