And that's probably because they were in the distributor with the heat and what's the chance they put the paste underneath when they replaced it. I have the hei on one car and plan on adding it to another but Once the wiring is in place they are an easy replacement if they do fail and they are cheap. You can run a hotter coil too. If it's good enough for the Renault Lecar, it's good enough for me.
