727 auto problem #790390
09/01/10 10:33 PM
09/01/10 10:33 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have a 727 torque flite and it slips from 2nd to third when I punch it. It also slips when the passing gear is engaged. I have changed the fluid and adjusted kickdown at WOT. 1st to 2nd shift is good. and 2nd to 3rd is good until I get on it. Is she dying on me?
Re: 727 auto problem [Re: roy2345] #790391
09/01/10 11:20 PM
09/01/10 11:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sure sounds like it.
Re: 727 auto problem [Re: stumpy] #790392
09/02/10 11:33 AM
09/02/10 11:33 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
are there any external adjustments that could be made?
Re: 727 auto problem [Re: roy2345] #790393
09/02/10 01:08 PM
09/02/10 01:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not that will stop slipping.
Re: 727 auto problem [Re: stumpy] #790394
09/02/10 06:00 PM
09/02/10 06:00 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
thanks
Re: 727 auto problem [Re: stumpy] #790395
09/02/10 07:20 PM
09/02/10 07:20 PM
Fort Lauderdale, FL
Suregrip Offline
Suregrip  Offline
Fort Lauderdale, FL
Make sure the fluid is checked in neutral, with the engine running. Also adjust the bands according to the manual, not really hard to do...
Some people you just can't reach...
Re: 727 auto problem [Re: Suregrip] #790396
09/02/10 08:18 PM
09/02/10 08:18 PM
scratchnfotraction Offline
no adjustment for slipping front clutches
if thats whats slipping
got a spare yet?
I went to Macon Ga. to get a 71 long tail shaft BB727 for a a999 hs/lu swap
how far is the band adjustment showing above the shift lever on it?
if its not a lot,that band has most likly been used up some with adjustments
the more threds showing the better
still if the clutches are toast no adjustment
how does the fluid smell? burnt? dark color?
leaks and low on fluid?
found a spare yet?
dont know much about them,but have changed a lot of them in just about every thing that had them, since I was 16 and
good luck with it
good times are when they are "used" and work
but i have changed a couple 2x cause they looked good "used" sitting on some shop floor and no worky..
Re: 727 auto problem [Re: scratchnfotraction] #790397
09/02/10 11:11 PM
09/02/10 11:11 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok will recheck fluid level. It will drive in 3rd. Just hate the sloppy shift.
Re: 727 auto problem [Re: roy2345] #790398
09/03/10 09:40 AM
09/03/10 09:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What's the history of the transmission and did you check adjustment of the front band ?
Re: 727 auto problem [Re: JohnRR] #790399
09/03/10 10:25 PM
09/03/10 10:25 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
How do I check front bands?
Re: 727 auto problem [Re: roy2345] #790400
09/03/10 10:35 PM
09/03/10 10:35 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
If there is a good 1-2 shift .. this is not a band issue.
Pull-the-pan and check what type of trash is in there.
Re: 727 auto problem [Re: roy2345] #790401
09/03/10 11:02 PM
09/03/10 11:02 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have pulled pan and changed filter. Only sloppy shift when I punch it
Re: 727 auto problem [Re: roy2345] #790402
09/04/10 05:27 PM
09/04/10 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Your front clutches are shot, time for an overhaul.
Re: 727 auto problem [Re: John_Kunkel] #790403
09/04/10 06:42 PM
09/04/10 06:42 PM
Indianapolis
Waveraider Offline
Waveraider  Offline
Indianapolis
Do it before this happens. Don't ask me how I know...
