Re: 70 B Body Education : Dash PLEASE
[Re: JMCFAN]
#790105
09/01/10 11:09 PM
09/01/10 11:09 PM
Posts: 1,304 Northern Indiana
mr_belvedere
super gas
super gas
Northern Indiana
JMC, If it isn't too much trouble, would it be possible for you to take measurements of the switch hole placement? (center of switch hole to reference point of your choosing)
I will be in need of this info also.
Thanks!
[Re: mr_belvedere]
#790106
09/01/10 11:21 PM
09/01/10 11:21 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
not a problem. Gve me till tomorrow.
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: anlauto]
#790111
09/03/10 11:00 PM
09/03/10 11:00 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
i have a template for the metal dash hole and screw holes with size,pm me if you need them and i'll have it for you tomorrow,switch mounts to metal frame,bezel only is mounted on plastic dash,switch is kinda off set,meaning that when put in frame toggle kinda angles towards the DRIVER,i mounted the set up im my 70 runner non air grabber and with the template from a older member(b body bob)everything went perfect.pm me if i can be of any help
[Re: anlauto]
#790112
09/03/10 11:27 PM
09/03/10 11:27 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Just to clarify... The white plastic switch mounts on the backside of the metal dash frame with two screws... NOT on the outside between the metal frame and plastic bezel.
The bezel mounts to the plastic using two more screws.
Where does the solenoid go?
Terry I could take you up on the offer, but now I only need the solenoid. How do you tell if used ones work?
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#790113
09/03/10 11:42 PM
09/03/10 11:42 PM
Posts: 3,054 USA
b54406barrel
USA
Just to clarify... The white plastic switch mounts on the backside of the metal dash frame with two screws... NOT on the outside between the metal frame and plastic bezel. Yes from behind, but I don't know how many screws hold it, can't see.
The bezel mounts to the plastic using two more screws. Yes
Where does the solenoid go? Close to ashtray, again can't see up there very well. I would think a FSM would show it
[Re: anlauto]
#790117
09/04/10 10:54 AM
09/04/10 10:54 AM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
I've never seen a used one fail unless one of the plastic tabs is broken or the wiring lets go. More chance of Sum Yung Gy building them overseas for PG Classic not putting one together right. You'll also need a fitting like this on the engine.
[Re: mccannix]
#790119
09/04/10 11:36 AM
09/04/10 11:36 AM
Posts: 3,054 USA
b54406barrel
USA
On my rr that manifold fitting has the large central vac nipple for pb & the small side one, not the 2, 5/16" nipples. Wonder what a non-pb car fitting looked like?
[Re: anlauto]
#790120
09/04/10 11:37 AM
09/04/10 11:37 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
No problem hijacking...We're all on this flight together.. Just don't say..."i have a bome" ... (bomb)
Does your car have some sort of "Deluxe" seat beat option..
I'm not sure. The car came without the belts and there is no build sheet.
Nothing special is designated on the fender tag except buckets with console.
[Re: coffeeman383]
#790124
09/04/10 03:32 PM
09/04/10 03:32 PM
Finoke
Horsham, Pa.
Same car, deluxe seat belts (button style). The C15 would be window sticker or build sheet only (not on the tag).
Also notice that this car has the wrong door panels (standard non-RR decor)???
Good info Coffeeman!
No paint yet. But the body work is progressing. They are about half way there. The bodywork on the entire rear half of the exterior is done.
