70 B Body Education : Dash PLEASE
#790085
09/01/10 03:34 PM
09/01/10 03:34 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
OK... 1970 Plymouth B Body with factory AIR GRABBER... Is this the correct dash location? Is the metal frame different, because there is not much room behind this switch hole location.
CHECK OUT MY NEW WEB SITE !
Re: 70 B Body Education : Dash PLEASE
[Re: anlauto]
#790088
09/01/10 03:37 PM
09/01/10 03:37 PM
anlauto
PG Classics lists a "air grabber solenoid" in their catalog...Do I need that as well? Where does it mount?
[Re: anlauto]
#790090
09/01/10 03:42 PM
09/01/10 03:42 PM
Posts: 3,054 USA
b54406barrel
USA
On top of the glove box, I think. Again, been so long...........
[Re: anlauto]
#790091
09/01/10 03:45 PM
09/01/10 03:45 PM
anlauto
OK, so my location looks right...I wonder if that "white block" of the switch screws directly to the metal frame?
Also (unrelated) If you don't want a map light, located just to the right of the heater controls, is there some sort of "block off plate" or something? Where could I get one of those?
[Re: anlauto]
#790092
09/01/10 03:56 PM
09/01/10 03:56 PM
Posts: 3,054 USA
b54406barrel
USA
My switch is really solid so it must be screwed to frame. I don't have a light so yes, there is a block off plate. Bad picture though. Never looked for a repop one.
[Re: anlauto]
#790093
09/01/10 04:03 PM
09/01/10 04:03 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
A correctly placed want ad , it's a metal plate , at least in 68 and 69 it's metal.
[Re: b54406barrel]
#790094
09/01/10 04:15 PM
09/01/10 04:15 PM
anlauto
Rex Is your glove box blue inside or black? I'm referring to the backside of the actual door? John, thanks for that "want ad" tip
[Re: anlauto]
#790096
09/01/10 06:38 PM
09/01/10 06:38 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Alan,
Backside of the door should be black. I have a spare maplight if you want it, but I used my only blank off plate....sorry.
Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: anlauto]
#790098
09/01/10 09:28 PM
09/01/10 09:28 PM
anlauto
I was told that the plastic bezel was an original, but I guess it's possible the steel frame has been changed It would seem to me that the switch should be anchored to the steel frame for strength ?
[Re: b54406barrel]
#790100
09/01/10 10:47 PM
09/01/10 10:47 PM
Posts: 2,096 New Mexico
JMCFAN
New Mexico
I have the dash out of my 70 RR airgrabber car now. took a photo. Does it help?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: anlauto]
#790103
09/01/10 10:57 PM
09/01/10 10:57 PM
JMCFAN
New Mexico
there are some there.. bad photo. Wil take a couple more
[Re: JMCFAN]
#790104
09/01/10 11:04 PM
09/01/10 11:04 PM
JMCFAN
New Mexico
How is this I removed the airgrabber switch you have in our photo when I started striping it down. I tink I have photos of that as well.
