Re: ?? full 1/4 install 69 r-r-do i remove the drip rails
[Re: dodgem1]
#789688
09/01/10 12:17 AM
09/01/10 12:17 AM
Posts: 18,160 Mass
DAYCLONA
Mass
No, using the AMD panels, the leaded seam will be in the "factory" location, no need to remove the drip rail,....here's a pic of some AMD full qtrs I installed on a customers car, everything lined up excellent, no surgery needed,...just like NOS skins, if not better
Mike
[Re: dodgem1]
#789693
09/01/10 08:36 AM
09/01/10 08:36 AM
Posts: 490 Boston Ma
Hamtramck
Boston Ma
how did the rear side markers fit? I had heard that the recess was off and needed to be filled a bit on the first run of panel.? ![](/ubbthreads/images/graemlins/bondo.gif) Did they correct that?
69 roadrunner conv. 4spd B5/X9
[Re: dodgem1]
#789698
09/02/10 10:17 AM
09/02/10 10:17 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
i will prob do it this way,but even if i slice at the rail i still cant get the old piece of 1/4 out from under the roof?and i just looked my amd s dont have the lip that folds under the rail like the origonal?
You will leave the old piece under the drip rail, then trim the new quarter to fit that area, then mig weld the new and old together at that seam. This means you will leave the drip rail alone completly. Use a cutoff wheel to slice the "C" pillar along the edge of the drip rail to separate the quarter from that area.
