Hoosier Quick Time Pro #789207
08/31/10 02:19 PM
08/31/10 02:19 PM
St. Clair Shores, Michigan
bigsbigelow Offline OP
I have been researching tires lately and noticed that Hoosier offers the Quick Time Pro in a 26 x 9.5 with an 8" tread for a 14" rim. The required wheel width is 6" to 8". The tire is measured on an 8" wide rim. Do any members run these on a 6" wide rim? Are there any issues running a tire on a rim smaller than what it is measured on.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
383man [Re: bigsbigelow] #789208
08/31/10 02:37 PM
08/31/10 02:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We run the Hoosier QTP tires on my sons Dart and they are the 26 x 9.5 x 15 as we run the 15" wheel. He uses a 7" rim which has worked fine for us but an 8" wheel will give more tire track. You are pushing it on a 6" wheel but I did run 9 x 28 slicks on a 6" wheel once. It had alot of sidewall buldge. Ron
