5.9 Magnum info
#788961
08/31/10 12:42 AM
08/31/10 12:42 AM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
A while back I bought a 5.9 Magnum engine from a local guy here. What was the lift & duration spec's on the stock cam? Needed for comparision purposes. Also I have a Profesional products intake for a Magnum along with some nice headers. If I where to rebuld it back to stock specs & install these would I pick up much? Say 30 HP at least? Trying to stay with the stock cam if I can. Its a budget build.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: 5.9 Magnum info
[Re: rockerbob]
#788962
08/31/10 01:07 AM
08/31/10 01:07 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
The 360 magnum cams are small, VERY small, like 390 lift small , if your planning on having any nice gain, send it out to Bullet cams for a re-grind, Tim is by far the best, he did mine for 150.00, he stretched it to the limit, .477,.477-.218,.218 @50, & set it up on a 112, its still a very mild & wimpy cam, but it has good torgue, i can only get 5100 out of it, but i'm running the prof.products intake, that could be some of the limiting factor, i wouldn't even dream of running this cam in stock form , unless your wanting a pull rig with high gears.
Re: 5.9 Magnum info
[Re: joedust451]
#788963
08/31/10 06:35 AM
08/31/10 06:35 AM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
.410 for the 5.9, .430 for the 5.2
You can also buy 1.7 rockers which whill increase the lift and duration somewhat.
.430 + 1.7 = .460
Re: 5.9 Magnum info
[Re: joedust451]
#788964
08/31/10 08:40 PM
08/31/10 08:40 PM
rockerbob
Raleigh, NC
No its a 100 % strip car. I just was hoping to use the stock cam for now & upgrade later. But I dont want to run slower than my current 318. These engines pull decent in those big heavy Rams so I was hoping in my 3200 pound car (with driver) it would have the torque to get a little et improvement.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
Re: 5.9 Magnum info
[Re: rockerbob]
#788966
08/31/10 08:49 PM
08/31/10 08:49 PM
gdonovan
Oakdale CT
.430 + 1.7 = .460
Is that .410 at 1.5 or 1.6?
.410 lift is with stock 1.6 magnum rockers.
Stock magnum is 1.6, LA is 1.5
Re: 5.9 Magnum info
[Re: rockerbob]
#788968
09/01/10 09:54 PM
09/01/10 09:54 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
A good cam/manifold/header setup will really make a 360 mag long block come alive, you can gain 125-150hp over stock depending on how big of a cam you run. I warmed up a 318 mag like that and picked up 80hp at the wheels, it was a mild truck motor that still pulled 17-18" of vac at idle - I had a 206@.050 cam in it.
