Re: coil over front end with stock upper and lower a arms??
[Re: Blown61]
#788826
09/04/10 04:53 PM
09/04/10 04:53 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
[Re: mopowers]
#788827
09/06/10 12:12 PM
09/06/10 12:12 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
The pivot pin.
So that is nothing more then a cover and the pivot pin does all the support work?
[Re: HEMIFRED]
#788829
09/07/10 12:53 AM
09/07/10 12:53 AM
Blown61
wisconSIN
The pivot pin.
it holds in my bushing also
Doesn't the pin go thru a bushing?
[Re: Magnum]
#788831
01/12/11 05:16 AM
01/12/11 05:16 AM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
I see a bolt back there. Maybe it's fastened to the lower control arm shaft to keep the arm from pushing towards the rear of the car.
There is no way the arm will fall off. The front strut will not allow that but it may pull back a bit without the tension of the torsion bar on the hex.
How do you tighten this bolt and still allow the lca to pivot freely?
[Re: John Burdine]
#788832
01/12/11 05:27 AM
01/12/11 05:27 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
On a side note...
Fred, you think with the way you have your arms setup etc. a rack / pinion steering would fit using a stock k-member too?
[Re: 72Challenger]
#788833
01/12/11 10:22 AM
01/12/11 10:22 AM
Posts: 6,146 Melbourne , Australia
LA360
Can a bearing be used in place of a bushing?
I imagine the washer buts up to the shaft, allowing some clearance between the washer and the control arm?
Thanks in advance
Alan Jones
[Re: LA360]
#788834
01/12/11 04:55 PM
01/12/11 04:55 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
by removing the torsion bar, and using a coil over you are putting the load through the shock tower where the car was designed to support the springs through the trans crossmember. the shock tower's aren't up to it. I've heard it bends the car i.e. people have problems closing doors ..panel alignment etc.over time. good to hear member's experiences with c/o replacements..
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#788835
01/12/11 05:26 PM
01/12/11 05:26 PM
72Challenger
Netherlands
Yeah, if you do change over to coil overs in my eyes it's a must to add some kind op bracing / support for cause as you said the stock shock towers aren't designed to carry the load. Assume if using stock upper arms you have to change the upper shock / coil over mounts anyway for clearancing.
[Re: Blown61]
#788838
01/12/11 09:25 PM
01/12/11 09:25 PM
Posts: 2,648 GA
Boosted
GA
I would love to know more about this for a street car... I am tired of working around the t bars with my headers...
Anyone make a bolt in kit?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Boosted]
#788839
01/12/11 09:35 PM
01/12/11 09:35 PM
Posts: 2,449 nc
earthmover
nc
i would also like to know see more pic from diff. angles thinking of going this way with my big block duster project.. so anymore info you guys can give or show would help out thanks mike also what kinda rack is that fred??? did you have to do any bending of the lower ball joint mounts when went to the opp. side??? i think it was in another post before but not sure
[Re: Keith Black®]
#788840
01/13/11 02:41 AM
01/13/11 02:41 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Who says the shock towers are not up to it. My GTX, simply had a piece of 1" tubing welded across the shock tower, inside, on the wheel side. The tabs for the shocks were on this piece of tubing. No snout bars, no other supports or gussets, nothing. The front end alignment NEVER moved, this tells you the shock towers NEVER moved. Performed this conversion on more than one car and the shock tower carries the load just fine.
Monte
[Re: Jeepmon]
#788842
01/13/11 10:33 AM
01/13/11 10:33 AM
Posts: 2,648 GA
Boosted
GA
hey Monte.... Who sells this kit or is it one of those special things a person has to put together?
Anyone use this on a street car?
2011 RAM3500
[Re: Boosted]
#788844
01/13/11 12:16 PM
01/13/11 12:16 PM
Posts: 4,085 The Wet Coast, Canada
megajoltman
Here's the parts I will be using when I do mine:
aftermarket upper control arms(seems to give you way more room for the coil-overs imo)
coil over shocks and springs
a spanner wrench to adjust the shocks
a set of spring bearings to make the ride height adjustments easier
My cage will be tied into the shock towers so they will be fine.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
