Re: upgrading Accesory Wiring-What needs a constant hot?
[Re: challenger70]
#788526
09/01/10 12:11 AM
09/01/10 12:11 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
That's a bunch of questions. I'll throw in what I caught out of all that.
A split box will leave you with options to go either way. Like if you have an automatic fan. This can stay running when you shutdown a hot engine. The heavier kit will not be helpful if you are not using it for the high amp accessories which have their own feed through a relay. If the fusebox is only for the switching circuit, 10 amps is plenty. MSD boxes are usually wired to a constant hot, then switched through the ignition.
