Is my regulator working correctly? #788452
08/30/10 03:35 PM
08/30/10 03:35 PM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
I used oil to help get some Push-Loc fittings on the fuel lines. Wanting to flush the lines with gas before connecting to the carbs, I powered up the pump and I just get a dribble out of the hose. Sorry, didn't measure volumes. Even backing the adjustment screw all the way out doesn't make much difference.
Disconnected the regulator and the pump shoots a high volume of gas (looks easily over 100 gallons/hour).
How much gas should get to the carbs?
Roy
Re: Is my regulator working correctly? [Re: royt440] #788453
08/31/10 04:25 PM
08/31/10 04:25 PM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
I think I flushed the oil out so I hooked up to the two Edelbrocks. The pressure was steady at 9 and screwing in on the regulator raised it to 12. I couldn't get it any lower than 9.
Is that too much?
The regulator has another "out" port that I could use as a return line.
Any input?
Thanks,
Roy
Re: Is my regulator working correctly? [Re: royt440] #788454
08/31/10 05:12 PM
08/31/10 05:12 PM
Andrewh Offline
Andrewh  Offline
quick search says you should have max 6psi fuel pressure min 4 psi at wot.
What size is your return line? perhaps it is the restriction?
See if you let it dump to a bucket if you can get under 9 with it wide open.
what kind of regulator
