Synthetic oil #788104
08/30/10 12:38 PM
08/30/10 12:38 PM
Slidell, la.
1BAD383 Offline OP
08 SRT Challenger
1BAD383  Offline OP
08 SRT Challenger
Slidell, la.
Will synthetic oil cause some oil leaks on a car that is 9 years old. We purchased the car a year ago, and it had used regular oil. Then when I got the oil changed, I put synthetic oil in.
Re: Synthetic oil [Re: 1BAD383] #788105
08/30/10 12:43 PM
08/30/10 12:43 PM
Colorado Springs, Colorado
Dartthunder340 Offline
I did not have a problem switching to a full synthetic oil in my '95 Ram for a period of time. Since then things have gotten a little tight so I have gone to a Valvoline blend. But I did'nt see any leaks at all. Hope it helps.
edit: switched at over 100,000. Truck still runs fantastic.
Better get inside Ma. Looks like a storm's comin'.
Re: Synthetic oil [Re: 1BAD383] #788106
08/30/10 02:15 PM
08/30/10 02:15 PM
P
Paul_Fancsali Offline
P
Usre the high mileage oil valvoline or pensoil its works great and leaks will slow down to virtually disappear. Not for pouring leak
Re: Synthetic oil [Re: 1BAD383] #788107
08/30/10 02:48 PM
08/30/10 02:48 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
Synthetic oil flows much better, if you have a small leak it could enhance it, but havn't seen it happen to often
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Synthetic oil [Re: deansrr] #788108
08/30/10 02:50 PM
08/30/10 02:50 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Mobil 1 has the high mileage oil now too.
My
Own
Personal
Adrenaline
Rush
Re: Synthetic oil [Re: Moparzrule] #788109
08/30/10 05:40 PM
08/30/10 05:40 PM
Slidell, la.
1BAD383 Offline OP
08 SRT Challenger
1BAD383  Offline OP
08 SRT Challenger
Slidell, la.
It's a very small leak, a couple of drops a day.
Re: Synthetic oil [Re: 1BAD383] #788110
08/30/10 08:40 PM
08/30/10 08:40 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Darthunder340, blend your own. Legally, all they have to do is put a tablespoon of synthetic in and they can call it a "Blend" Most folks think it is 50/50 but its not. Put in two quarts of good synthetic on a 6 qt. change and you get most of the benefits of synthetic. Dave Vizard wrote an article several years ago about this.
Re: Synthetic oil [Re: Lee446] #788111
08/30/10 10:44 PM
08/30/10 10:44 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Synthetic oils flow better, the molecules are consistent and not irregular like conventional oils.
They won't cause a leak. Most likely you had a leak somewhere and the synthetic oil found it's way out.
Re: Synthetic oil [Re: Lee446] #788112
08/31/10 12:24 AM
08/31/10 12:24 AM
Lee446, thanks for the info about that. I am coming up on a change and will switch.
