Page 2 of 3 1 2 3
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787650
08/30/10 08:57 PM
08/30/10 08:57 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
hay mike you going big block we're in the planing stage for my sons car now and dec. on what we're going to do with the backend .
Re: M.P. STAGE 6 HEADS [Re: earthmover] #787651
08/30/10 09:40 PM
08/30/10 09:40 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Hey Mike......Naw,Im a SB guy and probably would never run a BB UNLESS I found one cheap enough.
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787652
08/30/10 10:48 PM
08/30/10 10:48 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i know what you mean .my son told me that once he beats me with his big block i'll change over but he forgot im the 1 building the motor so he's not going to be fast at all hahaha but we're going to try and make some preety good power with this thing if all works out for him.... you got the duster out yet??? i went out friday night and had a good time car ran ok 7.58 with a 1.63 short time the trans is going out in it i think its glideing in gear and not snapping like it use to ..but its been in the car since 99/2000 so hay its time...but im gonna try a new filter and fluid and see how it goes ...still gotta find out where i lost my time but im having fun with it thats all the matters..
Re: M.P. STAGE 6 HEADS [Re: earthmover] #787653
08/30/10 11:08 PM
08/30/10 11:08 PM
iowa
rook440 Offline
rook440  Offline
iowa
I have a set of factory hand ported stage vi heads that made 650 hp and 650 tq at midwest racing engines on a 505 with 13 to 1 compression and a 700 lift roller ....power was all in by 5700 tho ...frankly I like them ..they have their faults tho ....lots better than 915s
Re: M.P. STAGE 6 HEADS [Re: rook440] #787654
08/31/10 09:07 AM
08/31/10 09:07 AM
Hey Mike....It is running but we kind of "Threw it together" so I was able to load it on and off the trailer. So before I take it to the track,its got to cool down first and I need to check EVERYTHING over to make sure its ALL right. I will let you know when I go racing.
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787655
08/31/10 10:31 AM
08/31/10 10:31 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
had them on the duster when I first bought him...they were non maxwedge...just cleaned up..with a .557 cam, 1050 dom, Ebrock intake with adapters(I have a set available too)12.5 ross pis. and at a weight of 3300lbs w/driver(must have been a heavy driver), MAX was consistant 10.0's...
had Crane 1.52 rockers(Dove)
bad part was the LY rods which seemed to have snapped many times as there were 4 sleeves in the block and many dents and repairs to the oil pan...LOL
Re: M.P. STAGE 6 HEADS [Re: smokinwoody] #787656
08/31/10 04:44 PM
08/31/10 04:44 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I like mine so far.
67' charger 499 RB 10.57 at 127
Re: M.P. STAGE 6 HEADS [Re: dragram440] #787657
08/31/10 07:12 PM
08/31/10 07:12 PM
under a rock
flathood Offline
flathood  Offline
under a rock
Re: M.P. STAGE 6 HEADS [Re: flathood] #787658
08/31/10 08:35 PM
08/31/10 08:35 PM
organ
maximum entropy Offline
organ
Useful info http://www.moparmusclemagazine.com/techa...ting/index.html
those be the stage vi chapmans. very expensive, and VERY good! those heads are amazing. too bad i'm not awash in lucre!
Re: M.P. STAGE 6 HEADS [Re: maximum entropy] #787659
09/02/10 04:11 PM
09/02/10 04:11 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I run them on my 500ci 575hp crate engine. I just got these today for $999.99 too good to pass up
http://slo.craigslist.org/pts/1862914057.html
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: M.P. STAGE 6 HEADS [Re: BloFish] #787660
09/02/10 05:14 PM
09/02/10 05:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Are those "out of the box"? Not sure from the description.
I can tell you from first-hand experience that "out of the box" Stage VIs can require a lot of $$$ to make 'em right, even if you get them cheap to begin with. MP had a whole bunch of different quality control issues w/ those things, even after the original leaking castings were long gone.
They're simply not cost-effective to buy 'em new and have to pay for all the "fix it" work needed, compared to the other choices available today. It's a shame, too, because they can work really well, once finished properly.
Re: M.P. STAGE 6 HEADS [Re: BradH] #787661
09/02/10 05:41 PM
09/02/10 05:41 PM
On the run…
On the run…
They are right out of the box, he even included new Mopar valves. I just had Harland Sharp make me a custom set of rockers/shafts with the proper offset for my existing stage VI heads, that's why I bought these. I won't be trying another brand anytime soon
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: M.P. STAGE 6 HEADS [Re: BloFish] #787662
09/02/10 05:52 PM
09/02/10 05:52 PM
Nice deal!!!!! Are you having someone port and flow them??
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787663
09/02/10 06:05 PM
09/02/10 06:05 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I had a set on my 496 low deck stroker...ported first by Muscle Motors on my stock stroke 440..went 5.28 in the 1/8 on my dragster...built my low deck and had them re-ported by a local small block chevy "expert" (I know, I know)...they then went 4.86 at 140 in the same dragster with the addition of a roller cam (old 440 was a flat tappet) the stock block engine made 782hp on the dyno. So I guess I am happy with my stage VI's. My
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787664
09/02/10 07:10 PM
09/02/10 07:10 PM
On the run…
On the run…
I will have Dwayne Porter do them for me.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: M.P. STAGE 6 HEADS [Re: Wicked49670dart] #787665
09/02/10 07:49 PM
09/02/10 07:49 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Hmm I know where there is a set for sale . . . Close to Florida too.
https://board.moparts.org/ubbthreads/download.php?Number=6115824
I'm Gumby dammit!
Re: M.P. STAGE 6 HEADS [Re: rook440] #787666
09/02/10 09:35 PM
09/02/10 09:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Interesting.... Mine are small ports that I purchased from Muscle Motors and then later sent to Dewayne Porter (picts and info in the archives here) for additional work. While I've never dynoes the engine, we've shifted as high as 6200 and not had any gain over the 5600 shift point we've had it set at forever. I run the old tried and true Ultradyne NF 69 flat tappet grind. We did pick up a ton though when we finally removed the M1/850cfm 4150 carb and went with the M1 stage VI 4500 intake and a Carb Shop 1050. Engine is plenty powerfull for low 10 fun and easy on parts.
Re: M.P. STAGE 6 HEADS [Re: J_BODY] #787667
09/03/10 08:19 AM
09/03/10 08:19 AM
Do you have to use spacers all the time with Stage 6's??
Re: M.P. STAGE 6 HEADS [Re: MIKES_DUSTER] #787668
09/03/10 09:07 AM
09/03/10 09:07 AM
Utah
topbrent Offline
topbrent  Offline
Utah
RB block: yes* spacers required when using a traditional RB intake and RB block.
B block: no spacers needed if using an RB intake on a B block. B intake& B block = spacers needed.
*: no RB spacers required if you use one of the wider Stage VI specific Mopar M1 intakes available for RB motors. The spacers are cast in already as is the valley tray.
- P4532758 Dominator Flange
- P4876128 MW port 4150
- P4532757 ?MW port?
Re: M.P. STAGE 6 HEADS [Re: topbrent] #787669
09/03/10 11:12 AM
09/03/10 11:12 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and pay close attention to "traditional" RB intake. There were M1 intakes made to fit the RB/stage VI combo that did away with the spacers. That's what I currently run, but I still have my old "traditional" M1 and spacers stored away.
Page 2 of 3 1 2 3
