Re: M.P. STAGE 6 HEADS
[Re: BloFish]
#787660
09/02/10 05:14 PM
09/02/10 05:14 PM
BradH
I just got these today for $999.99 too good to pass up
Are those "out of the box"? Not sure from the description.
I can tell you from first-hand experience that "out of the box" Stage VIs can require a lot of $$$ to make 'em right, even if you get them cheap to begin with. MP had a whole bunch of different quality control issues w/ those things, even after the original leaking castings were long gone.
They're simply not cost-effective to buy 'em new and have to pay for all the "fix it" work needed, compared to the other choices available today. It's a shame, too, because they can work really well, once finished properly.
[Re: rook440]
#787666
09/02/10 09:35 PM
09/02/10 09:35 PM
Posts: 13,227 aZLiViN
J_BODY
aZLiViN
I have a set of factory hand ported stage vi heads that made 650 hp and 650 tq at midwest racing engines on a 505 with 13 to 1 compression and a 700 lift roller ....power was all in by 5700 tho ...frankly I like them ..they have their faults tho ....lots better than 915s
Interesting.... Mine are small ports that I purchased from Muscle Motors and then later sent to Dewayne Porter (picts and info in the archives here) for additional work. While I've never dynoes the engine, we've shifted as high as 6200 and not had any gain over the 5600 shift point we've had it set at forever. I run the old tried and true Ultradyne NF 69 flat tappet grind. We did pick up a ton though when we finally removed the M1/850cfm 4150 carb and went with the M1 stage VI 4500 intake and a Carb Shop 1050. Engine is plenty powerfull for low 10 fun and easy on parts.
