Old carburetor clean-up chemicals?
#787352
08/29/10 08:02 PM
08/29/10 08:02 PM
Posts: 9,838 Detroit, Michigan, USA!
peelerboy
I've got an old Holley 650 vac.secondary that I'm rebuilding. The rear float bowl was damaged, but I was lucky enough to find another one at a local carb shop here in Detroit. Now I've got this spiffy looking rear float bowl while the other 75% of the carb looks nasty by comparison. Are there any chemicals/solutions out there that I can soak the carb's body and other float bowl in to brighten & clean it up? Another question, not really related, but looking for some miracle snake oil to solve my problems. I repainted my stock valve covers, but before doing so I removed the rubber grommets that seals the PCV and the breather can. These grommets are still intact, but are stiff from age and heat. Is there anything I can do to soften them up? (chemicals/solution)... or are there new grommets available for purchase at one of the many reproduction suppliers? Thanks in advance, guys! Dale
Re: Old carburetor clean-up chemicals?
[Re: peelerboy]
#787353
08/29/10 08:23 PM
08/29/10 08:23 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Don't know about restoring the finish, but I don't think you can do anything about the old rubber grommets except replace them. Most any good parts store will have replacements. Good luck on getting the old ones out. edit: Whoops, you got themout already. Mine had been in there for 35 years and a hassle removing
[Re: DZJim]
#787354
08/29/10 09:39 PM
08/29/10 09:39 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
MEK, wow buy it at lowes. put some in a old gas tank and it came out shiny. it will eat some rubber gloves
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: peelerboy]
#787357
08/30/10 01:33 AM
08/30/10 01:33 AM
Posts: 752 AZ - The "dry heat" state
71autoxr
I made an improvised soda blaster and used household baking soda to do mine. Came out like new. Mine had old nasty gas dried in the bowls and I was surprised how nice it was. While I didn't try MEK, I did use carb cleaner and brake cleaner to loosen it to no avail. When I was done with the body I did all the parts, then rinsed with water.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
[Re: 71autoxr]
#787358
08/30/10 01:56 AM
08/30/10 01:56 AM
peelerboy
I'm intrigued by this home brewed method you came up with. Can you go into a little more detail? You used baking soda...and what else? How did you apply it/soak it?
Dale
[Re: peelerboy]
#787362
09/01/10 11:48 AM
09/01/10 11:48 AM
Posts: 304 Ohio
LS-300
Ohio
This may sound weird but has been tried and works on motorcycle carbs. A mixture on 1/3 pine-sol and 2/3 water. This has been used and found out that is cleaned without damage to the rubber parts. It usually will be allowed to soak for a couple of days then the parts hit with compressed air. One gut actually rigged a palm sander to the bucket to make it similar to an ultrasonic cleaner. Using the Pine-sol (original) with the pine oil in it as the newer type doesn’t work without it.
1979 Chrysler 300
1968 Barracuda project
[Re: Ply72rr]
#787365
10/04/10 06:21 AM
10/04/10 06:21 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
carb cleaner dip
I've used this stuff in the past. It works well, I'll give it that, but it's so darn caustic that I'll be looking to other options with future projects...
