External oil line - Need Help! #787230
08/29/10 07:35 PM
08/29/10 07:35 PM
Garland, Texas
1badmopar Offline OP
Garland, Texas
I received my Rb back from the shop, but the engine mounts will not clear the external oil line. I am hoping someone can post a pic of the way you have your line run. This is my last hurdle before I drop this bad boy in the car!
Help!
Pics attached.
1966 Plymouth Belvedere
520" RB w/ Indy 440-1 Heads
FiTech Fuel Injection
TKO 600 conversion
[img]https://flic.kr/p/2j1ejsK[/img]
Re: External oil line - Need Help! [Re: 1badmopar] #787231
08/29/10 07:47 PM
08/29/10 07:47 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Can you post a pic of what you have.
Re: External oil line - Need Help! [Re: 1badmopar] #787232
08/29/10 07:59 PM
08/29/10 07:59 PM
Garland, Texas
Garland, Texas
Heres a pic. Sorry I had to figure out how to shrink the file on my new Mac. Hope this works.
TKO 600 conversion
Re: External oil line - Need Help! [Re: 1badmopar] #787233
08/29/10 08:00 PM
08/29/10 08:00 PM
Garland, Texas
Garland, Texas
One more...
TKO 600 conversion
Re: External oil line - Need Help! [Re: 1badmopar] #787234
08/29/10 08:27 PM
08/29/10 08:27 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Was you planning on using stock mounts?
Re: External oil line - Need Help! [Re: thehemikid] #787235
08/29/10 08:39 PM
08/29/10 08:39 PM
Garland, Texas
Garland, Texas
Yes. I used to run motor plates, but I am going back with the stock style mounts now.
I have seen several setups utilizing the stock mounts. I just cant remember how that ran their line. I think they use a front entry line into the pump, instead of the rear.
TKO 600 conversion
Re: External oil line - Need Help! [Re: 1badmopar] #787236
08/29/10 08:48 PM
08/29/10 08:48 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Yes most do run the front radial port with stock mounts. I'm running a axle ported Muscle Motors cover & Shumacher Hemi Adapter mounts on a stock 440 K member.If you have to stay with the factory mounting, you will probably have to change covers, or maybe go to the Milodon pump w/front entry.
Re: External oil line - Need Help! [Re: 1badmopar] #787237
08/29/10 08:49 PM
08/29/10 08:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You have the wrong end cover for stock RB mounts. That cover will work with Hemi mounts but not RB. You need the cover with the line coming out the end - not the back. Buy the Muscle Motors one piece cover and solve potential gasket leaks at the filter mount at the same time!
Note: if you go with the front entry plate like a previous post suggests then you'll have to change the oil pump drive shaft/gear for the longer one as that plate moves the pump away from the block by about 3/4". You'll also need more/different fittings and a longer line.
The MM plate is the easy solution.
Re: External oil line - Need Help! [Re: Stanton] #787238
08/29/10 08:59 PM
08/29/10 08:59 PM
Garland, Texas
Garland, Texas
Thanks guys! Makes sense. I will contact Muscle Motors in the morning!
TKO 600 conversion
Re: External oil line - Need Help! [Re: Stanton] #787239
08/29/10 09:01 PM
08/29/10 09:01 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...If you decide to run the MM cover there is a O-ring issue (to me) to deal with. I'll show you latter.
Re: External oil line - Need Help! [Re: thehemikid] #787240
08/29/10 09:19 PM
08/29/10 09:19 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...In my opinion the cover needs to be machined to remove the lettering from around the O-ring seat, & then redo the seat so it has no irregularities to cut the O-ring. Thats what I'm doing to mine.
Re: External oil line - Need Help! [Re: thehemikid] #787241
08/29/10 09:57 PM
08/29/10 09:57 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As stated, you need a cover plate with the side hole/fitting. You could modify yours but the Milodon one that comes with the side hole has a boss for the additional hole so it may be a little thin on yours for the rquired threads. Also, if you do run the Milodon, think about eliminating the green filter adapter plate gasket and machining the cover for "O" rings instead. A number of threads on here talking abouot that modification.
Here's a few shots of how I got around the mount problem.
Re: External oil line - Need Help! [Re: PC-CHARGER] #787242
08/29/10 09:58 PM
08/29/10 09:58 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
#2
Re: External oil line - Need Help! [Re: PC-CHARGER] #787243
08/29/10 09:59 PM
08/29/10 09:59 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
#3
Re: External oil line - Need Help! [Re: PC-CHARGER] #787244
08/29/10 10:37 PM
08/29/10 10:37 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...you can be stealth also by going through here.
Re: External oil line - Need Help! [Re: thehemikid] #787245
08/29/10 10:43 PM
08/29/10 10:43 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...then there's the Milodon pump option.
Re: External oil line - Need Help! [Re: PC-CHARGER] #787246
08/29/10 10:54 PM
08/29/10 10:54 PM
Garland, Texas
Garland, Texas
It appears that you have to cut the K Frame to run the top mount. Is that true?
Thanks.
TKO 600 conversion
Re: External oil line - Need Help! [Re: thehemikid] #787247
08/29/10 11:03 PM
08/29/10 11:03 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...and if you wanted to get a little crazy on the "Pump Prime" Idea. (disregard the whimpy loom)
Re: External oil line - Need Help! [Re: 1badmopar] #787248
08/29/10 11:10 PM
08/29/10 11:10 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
....No, his is cut because he's not useing a hose end that has a port fitting on it. look at my pic with the RED 120* hose end fitting, it's a closer fit & my K-frame is not cut. His cover appears to be a milodon though and I'm not sure as to what it wants O-ring wise.
Re: External oil line - Need Help! [Re: 1badmopar] #787249
08/29/10 11:14 PM
08/29/10 11:14 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Yes, there is a very small notch that was ground out of the K member. (see pic)
A friend of mine ran his through the mount much like thehemikid's picture shows. He had to modify a fitting to get the angle correct but it is an alternate way of doing it. The only downside is the line has to be left off one end or the other when removing or installing the engine and then attached once the engine is in place. Not a huge deal for most though.
