External oil line - Need Help!
#787230
08/29/10 07:35 PM
08/29/10 07:35 PM
Posts: 265 Garland, Texas
1badmopar
Garland, Texas
I received my Rb back from the shop, but the engine mounts will not clear the external oil line. I am hoping someone can post a pic of the way you have your line run. This is my last hurdle before I drop this bad boy in the car!
Help!
Pics attached.
1966 Plymouth Belvedere 520" RB w/ Indy 440-1 Heads FiTech Fuel Injection TKO 600 conversion [img] https://flic.kr/p/2j1ejsK[/img]
Re: External oil line - Need Help!
[Re: 1badmopar]
#787231
08/29/10 07:47 PM
08/29/10 07:47 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...Can you post a pic of what you have.
[Re: 1badmopar]
#787232
08/29/10 07:59 PM
08/29/10 07:59 PM
1badmopar
Garland, Texas
Heres a pic. Sorry I had to figure out how to shrink the file on my new Mac. Hope this works.
[Re: thehemikid]
#787235
08/29/10 08:39 PM
08/29/10 08:39 PM
1badmopar
Garland, Texas
Yes. I used to run motor plates, but I am going back with the stock style mounts now.
I have seen several setups utilizing the stock mounts. I just cant remember how that ran their line. I think they use a front entry line into the pump, instead of the rear.
[Re: 1badmopar]
#787236
08/29/10 08:48 PM
08/29/10 08:48 PM
thehemikid
ky hills
...Yes most do run the front radial port with stock mounts. I'm running a axle ported Muscle Motors cover & Shumacher Hemi Adapter mounts on a stock 440 K member.If you have to stay with the factory mounting, you will probably have to change covers, or maybe go to the Milodon pump w/front entry.
[Re: Stanton]
#787238
08/29/10 08:59 PM
08/29/10 08:59 PM
1badmopar
Garland, Texas
Thanks guys! Makes sense. I will contact Muscle Motors in the morning!
[Re: Stanton]
#787239
08/29/10 09:01 PM
08/29/10 09:01 PM
thehemikid
ky hills
...If you decide to run the MM cover there is a O-ring issue (to me) to deal with. I'll show you latter.
[Re: PC-CHARGER]
#787246
08/29/10 10:54 PM
08/29/10 10:54 PM
1badmopar
Garland, Texas
It appears that you have to cut the K Frame to run the top mount. Is that true?
Thanks.
[Re: 1badmopar]
#787248
08/29/10 11:10 PM
08/29/10 11:10 PM
thehemikid
ky hills
....No, his is cut because he's not useing a hose end that has a port fitting on it. look at my pic with the RED 120* hose end fitting, it's a closer fit & my K-frame is not cut. His cover appears to be a milodon though and I'm not sure as to what it wants O-ring wise.
[Re: thehemikid]
#787250
08/30/10 12:11 AM
08/30/10 12:11 AM
Posts: 8,916 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
In my opinion the cover needs to be machined to remove the lettering from around the O-ring seat, & then redo the seat so it has no irregularities to cut the O-ring. Thats what I'm doing to mine.
Good solution if you're a glutten for punishment with a machine shop at your disposal. Otherwise, pipe sealant on the threads and tighten the nut against the casting.
[Re: Stanton]
#787251
08/30/10 01:23 AM
08/30/10 01:23 AM
thehemikid
ky hills
You are correct, pipe sealant would be good, & easy. The port fitting/O-ring hose end, that I'm using, has very short threads, & its a low profile fitting that allows clearance so i don't have to cut my K-member. If I have mistaken the bevel on MM's axle port for a O-ring seat, then you are right again & I'm going to glutten a new seat
