Strange Cylinder Ridge in Rebuilt 340 #786842
08/29/10 10:27 AM
08/29/10 10:27 AM
Detroit, MI
FC7AARcuda Offline OP
Detroit, MI
I bought a rebuilt 340 to drop in my car until I get the original rebuilt. The engine was complete carb to pan, but I didn't hear it run. It looked clean, turned over fine and the price was right. I decided to replace all the gaskets before putting it in my car. After pulling the heads I found that every cylinder has a small ridge or taper about 1 1/2 inches from the top. No ridge at the very top. It's not enough to catch a fingernail on, but you can definitiely feel it. I was told the piston are .030+ speedpro and the motor has less than 1,000 mile on it. What would cause this? Is this something I can hone and still use?
Re: Strange Cylinder Ridge in Rebuilt 340 [Re: FC7AARcuda] #786843
08/29/10 10:57 AM
08/29/10 10:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Need pictures... are they all at the height on all 8 clys?
Re: Strange Cylinder Ridge in Rebuilt 340 [Re: Challenger 1] #786844
08/29/10 05:48 PM
08/29/10 05:48 PM
Detroit, MI
Detroit, MI
I can't get my camera to take up close pictures that show the wear pattern. It's in all 8 cylinders at about 1 1/2" down from the top of the cylinder(lower ring problem?). The pistons appear to be installed correctly (notch pointing towards front of engine).
Any ideas?
Re: Strange Cylinder Ridge in Rebuilt 340 [Re: FC7AARcuda] #786845
08/29/10 06:19 PM
08/29/10 06:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you sure that it isn't just a ring set mark from not being run for a period of time and will disappear with a little run time?
Re: Strange Cylinder Ridge in Rebuilt 340 [Re: FC7AARcuda] #786846
08/29/10 06:30 PM
08/29/10 06:30 PM
louisiana
bradybunch Offline
bradybunch  Offline
louisiana
could be a timing problem.
