aluminum radiator for a 70 dart #786736
08/29/10 01:44 AM
08/29/10 01:44 AM
Colorado
jr70swgr Offline OP
jr70swgr  Offline OP
Colorado
Which radiator and from where whould you guys recommend for a 70 dart swinger? Thanks!
Re: aluminum radiator for a 70 dart [Re: jr70swgr] #786737
08/29/10 06:29 AM
08/29/10 06:29 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Champion or Alumorad
Nautilus Racing-
Re: aluminum radiator for a 70 dart [Re: Chris2581] #786738
08/29/10 09:10 AM
08/29/10 09:10 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
best bang for the buck are summit radiators. get one that fits a ford, the inlet/outlet will be on the correct sides. just choose the width you need. they are not a bolt in, you will need to make/modify summits brackets. i did it, it was pretty easy.
Re: aluminum radiator for a 70 dart [Re: Chris2581] #786739
08/29/10 09:10 AM
08/29/10 09:10 AM
IN
ahy Offline
ahy  Offline
IN
I've had good results with the Mancini muscle car aluminum radiators
Re: aluminum radiator for a 70 dart [Re: ahy] #786740
08/29/10 09:42 AM
08/29/10 09:42 AM
okla.
O
okie Offline
okie  Offline
O
okla.
Check in the parts for sale ads on here, some guy on here sells the Champion radiaters. He has a good price and they are suppose to bolt in and work good. Ronnie
Re: aluminum radiator for a 70 dart [Re: okie] #786741
08/29/10 09:27 PM
08/29/10 09:27 PM
iowa
rook440 Offline
rook440  Offline
iowa
No to the Champion >>> I had to send one back as have others on Moparts ,because it had a 3/4 of an inch twist built into the radiator ... they did cover half of the shipping both ways ,I just had them return my money and bought a cross flow and had brackets welded on it ......
