Holley carbs... whats the difference??? #786597
08/28/10 10:47 PM
08/28/10 10:47 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
What is the difference in the
Holley 0-80496-1 950 HP
and the
Holley 950 Ultra HP, 0-80676 950cfm
Re: Holley carbs... whats the difference??? [Re: Jeepmon] #786598
08/28/10 10:53 PM
08/28/10 10:53 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The latter is an "Ultra" HP with billet throttle body and metering blocks
Monte
Re: Holley carbs... whats the difference??? [Re: Monte_Smith] #786599
08/28/10 11:20 PM
08/28/10 11:20 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
HP -
Ultra HP :
They both also have drilled plates
Re: Holley carbs... whats the difference??? [Re: Jeepmon] #786600
08/29/10 01:32 AM
08/29/10 01:32 AM
AndyF Offline
AndyF  Offline
Ultra HP carbs are set up for tuning. They have jets all of the circuits so they can be easily dialed in. If you have a wide band you'll be able to see what you're doing and can get the AF curve really nailed down.
Re: Holley carbs... whats the difference??? [Re: AndyF] #786601
08/29/10 01:34 AM
08/29/10 01:34 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A little off topic here but can tose holes be shrunk to cure a too fast idle?
Re: Holley carbs... whats the difference??? [Re: HotRodDave] #786602
08/29/10 04:24 AM
08/29/10 04:24 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If both the primary and secondary plates are fully seated and it will even idle, much less high, it is likely not the holes in the blades that are the problem. I would suspect a vacumn leak somewhere.
Monte
Re: Holley carbs... whats the difference??? [Re: Monte_Smith] #786603
08/29/10 12:34 PM
08/29/10 12:34 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks guys..
