Re: 2000 Dakota 4.7, any engine issues?
[Re: nd65]
#786432
08/29/10 03:20 PM
08/29/10 03:20 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
All I can say is I have a 4.7 with 138K in my 02 quad cab and it runs like a champ.Great engine IMHO.
[Re: ademon]
#786435
08/29/10 05:20 PM
08/29/10 05:20 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I had to replace the drivers side gasket on Mine @ 103,000. Heat the bolts up with a torch and they will come out easier. I didn't do that to mine and i broke two or three. then you'll have to drill and use an easy-out. The other problem is that at that mileage the nuts have rusted and are no longer a standard size. try and fine the closest size socket and tap it on with a mallet, or use vise grips( that really tears up the nuts). Gary
[Re: nd65]
#786437
08/30/10 08:36 PM
08/30/10 08:36 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
My 2000 4.7 just turned over 142K and I was getting a new muffler n tailpipe and the garage said mine is leaking on pass. side...2-3 hrs for $200. Looks mighty scary to do it on a weekend.
Still looking for LM29H1B415501, '71 Demon 340
