trans cooler #786293
08/28/10 03:54 PM
08/28/10 03:54 PM
california
moparmanof85 Offline OP
california
is there any reason i couldn't use the trans cooler for an engine oil cooler?
Re: trans cooler [Re: moparmanof85] #786294
08/28/10 04:57 PM
08/28/10 04:57 PM
scratchnfotraction Offline
as long as you got the lines to handle the oil pressure at the hook ups
dont see why not
I look for them on the cop car dippys/furys with sb to rob the line hook ups and cooler
you have got me to looking at adding it to my 440 now...
thanks..
oh..got me to wanting the 413 like yous down the road for the odd ball look under the hood now
that can go in my stepside when the 440 trucks done
keep us post on it and how you do it
need some pics of the hook ups
Re: trans cooler *DELETED* [Re: scratchnfotraction] #786295
08/28/10 05:17 PM
08/28/10 05:17 PM
california
california
Post deleted by moparmanof85
Re: trans cooler [Re: moparmanof85] #786296
08/28/10 05:21 PM
08/28/10 05:21 PM
california
california
for the record, when i did it to the 318, i put 2 drain rails in. under each valve cover. they were extra tall
Re: trans cooler [Re: moparmanof85] #786297
08/28/10 06:52 PM
08/28/10 06:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
here' a thought on the oil cooler. i plan to run it from the sender port on my 413, which has 2 sender ports, by the way. one for temp, the other for press. this may only be on the industrial, not sure.
Both of the ports at the back of the block are pressure, not temperature.
anyway, run from one of them to the cooler, and then i need to run it to a drain rail (think like a septic leach line) on the under side of the valley pan.
What you then have is a wide open leak which would drop the oil pressure.
Re: trans cooler [Re: John_Kunkel] #786298
08/28/10 10:43 PM
08/28/10 10:43 PM
would the sb block be the same open leak and drop the oil pressure also?
seen the same #LBS on the gauge with and with out the cooler on my sb cop motor swap
it went fom the galley right straight up from the pump to dump right back in thru the hollow FP bolt
unless the small hole was the restriction to hold pressure up
