Re: A/C question
[Re: convx4]
#785894
08/27/10 10:36 PM
08/27/10 10:36 PM
Posts: 40 Corona CA
wyotech_cuda440
Corona CA
Don't use compressed air, you need to keep the system clean and dry. You can fully charge it with r12 and then leak check, but r12 is pretty pricey. Instead, put an ounce or two of r12, and then pressurize it with nitrogen. Then you can use a sniffer to find the leak.
Daily driver: 2002 Dakota R/T, slightly modded
Weekend machine: 70 cuda, 440-6 street/strip
Re: A/C question
[Re: RapidRobert]
#785898
08/28/10 01:41 AM
08/28/10 01:41 AM
Posts: 40 Corona CA
wyotech_cuda440
Corona CA
More info on this please as I'm adding A/C to my 65 Dart (OE stuff w an under dash evap). First exp ever w A/C
Here's an article explaining it a bit, http://www.aircondition.com/tech/
If you are doing this yourself, you will need some freon, r22 or r12 for the test. r22 is cheaper, but you will need some r12 for the final charge anyway. Either type of freon will require an EPA liscense to purchase. You will need a tank of nitrogen, it's available at welding supply stores like Airgas, and you will also need a regulator for the nitrogen tank, plus you will also have to make up a hose that will connect to the regulator and the flare fitting on your car's a/c system. If you dont have a/c experience or liscenses, you should install the system, then take it to a shop for leak tests and charging.
Re: A/C question
[Re: RapidRobert]
#785900
08/28/10 11:17 AM
08/28/10 11:17 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Just convert to 134.Its easy and cheap.A lot of shops dont even have equipment for 12 anymore.That and you have to be real careful with any 12 you buy now.If its old stuff its OK.The newer 12 from offshore had some dangerous gases added to it.Some of the substitutes also had stuff like benzyne etc in it.Dye is probally the best to find a leak.It really shows up under a black light.We had sniffer and black light at the shop.99 % of the time I used the light.Also check the vacuum gauge/I had one that would leak down after a bit.I always pulled a vacuum and saw if it held for 15 minutes.Rocky
Chrysler Firepower
