Your ET's with RHS iron heads
#785820
08/27/10 07:05 PM
08/27/10 07:05 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
HI guys !! For reference....shouw YOUR et's with your combo using the RHS iron heads 1.92 or 2.02 int
My set up doesn't perform at all !
360 Magnum block 4.0 in stroker crank = 408 cu RHS heads 10.1:1 cr 250/250 flat tappet mecanical cam .525 lift 1.6 adjustable crane rockers 998 trans 2.77 first gearset 3.91 rearend with spool 3800 stall converter 28'' ET drag tires
Dan
Re: Your ET's with RHS iron heads
[Re: Wedgeman]
#785821
08/27/10 07:53 PM
08/27/10 07:53 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
For a street version of an RHS based 410: https://board.moparts.org/ubbthreads/show...part=1&vc=1Our 12.2:1 CR RHS-headed 416 has been 10.33 @ 131 at 3100# through the muffs. Granted, this is more race car than street car with a spool, 8" converter, etc. It also has a 2.45 low gear 904. Not knowing you timeslip deatails, the first thing that I notice is a low 1st gear coupled with a pretty tight conveter. It needs "flash" off the starting line to get it moving. Tell us more...
[Re: Wedgeman]
#785822
08/27/10 09:51 PM
08/27/10 09:51 PM
Posts: 1,051 The Great White North
RAMM
I'm not too far away and I have some info on those heads. Gimmee a shout on Monday at the shop 613-931-2157. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: cudadoug]
#785823
08/27/10 10:30 PM
08/27/10 10:30 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I immediately questioned converter as well.
Distributor, carb and timing info?
Post a time slip for us.
RIP Monte Smith
[Re: Wedgeman]
#785825
08/27/10 10:54 PM
08/27/10 10:54 PM
CompWedgeEngines
Syracuse,NY
A couple things stand out:
#1 Your 60' is killing you. Real bad. That is drastically hurting the ET
#2 I'm not so sure I'd be running 1.6 rockers on that. I am assuming these are untouched heads?
#3 Your back half MPH ( from 1/8th to 1/4 ) is a little weak. Its not pulling enough MPH there.
I'd concentrate on that 60' first. It will really improve that ET. How many passes have you made in it? Is it bogging, spinning, coughing etc on the launch?
What jets are in the carb?
RIP Monte Smith
[Re: RobX4406]
#785827
08/27/10 11:53 PM
08/27/10 11:53 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
How are you launching it?
What carb?
[Re: Wedgeman]
#785830
08/28/10 02:06 AM
08/28/10 02:06 AM
HotRodDave
Kalispell Mt.
Are you 100% sure the carb is opening 100% ?
[Re: HotRodDave]
#785831
08/28/10 02:08 AM
08/28/10 02:08 AM
HotRodDave
Kalispell Mt.
What RPM are you shifting at?
[Re: earthmover]
#785833
08/28/10 06:37 AM
08/28/10 06:37 AM
Posts: 2,578 sweden
1Fast340
sweden
Hay. How bout post your time slip
RT .533 60 ft 2.23 1/8 8.8 82.8 mph 1/4 13.6 99.3 mph
there is something very off here, unless this motor lives in a motorhome or something like that.. i bet its something very simple when you find it like carb not opening all the way maybe even not halfway or something else like that. or like writen earlier what does the car do how does it behave in the 60´
you will find the problem im sure ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MR_P_BODY]
#785835
08/28/10 10:03 AM
08/28/10 10:03 AM
Posts: 269 Kansas wishing I was in Ohio
SeanD
Is this engine in an A, B, C or E body????
What size fuel line from tank to carb?
Can you push the car on a flat/level surface without much effort?
What type/size tires are on car?
A lot of info is missing!
[Re: Wedgeman]
#785837
08/28/10 11:35 AM
08/28/10 11:35 AM
Posts: 5,160 Texas
dannysbee
Texas
The car will be harder to push if you are turning only, in a straight line it should be fairly easy to push. Your 60' is terrible but the mile per hour is way off also. There is something wrong whether it be timing, carburation, fuel delivery, engine or drive-train. Pick a spot and sort it out.
Getting old just means you were smarter than some and luckier than others.
[Re: Wedgeman]
#785839
08/28/10 01:06 PM
08/28/10 01:06 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
HI guys ! The engine is in a 67 Barracuda
Yes there was alot of slippage, non glue at the track, but even that, I should have a better top speed.. I checked the carb before going there
There is more effort to push a car with a spool for sure...
I start thinking may be the problem is in the trans itself.....
Dan
How did you check the carb to make sure you were getting WOT?
